Page 2 of 3 1 2 3
Re: Locking gas cap for '70 Challenger [Re: floyd] #882405
03/04/13 08:20 PM
03/04/13 08:20 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I did try that years ago without any sucess, it wouldn't fit right.(aftermarket gasket)
Both of your caps above are made for the filler neck on the left in my picture above. Neither would fit the neck on the right.
Yes the pressure vacuum on the right is messed up and junk. It originally fit the filler neck on the right in my photo above.
Re: Locking gas cap for '70 Challenger [Re: Challenger 1] #882406
03/04/13 11:04 PM
03/04/13 11:04 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Ah crud... I thought this was an ebody one... guess not. The rubber seal isn't that big.
Re: Locking gas cap for '70 Challenger [Re: Devil] #882407
03/04/13 11:21 PM
03/04/13 11:21 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
It looks like E-body to me, just that the seal is pretty much smoked (along with the rusty steel)
They can be disassembled for cleaning, re-plating and re-lubrication.
Re: Locking gas cap for '70 Challenger [Re: YYZ] #882408
03/04/13 11:39 PM
03/04/13 11:39 PM
Cincinnati, Ohio
Cincinnati, Ohio
Yup it looks like a E body to me? Isn't E body the only car to use a cap like that?
That one looks like it would fit the filler neck on the right in my photo above, it's the "other" locking filler cap I was talking about. I think there's 2 different rubber seals installed on the same locking cap to fit the 2 different filler necks?
And not vented says to me that it was 1970 cap without N-95.
Re: Locking gas cap for '70 Challenger [Re: Challenger 1] #882409
03/05/13 12:04 AM
03/05/13 12:04 AM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Ah, so I'm missing the second rubber piece then?
What do these go for?
Ryan
Re: Locking gas cap for '70 Challenger [Re: Devil] #882410
03/05/13 12:11 AM
03/05/13 12:11 AM
Cincinnati, Ohio
Cincinnati, Ohio
No I don't think you are missing anything.
Re: Locking gas cap for '70 Challenger [Re: Challenger 1] #882411
03/05/13 06:16 PM
03/05/13 06:16 PM
Germany
walkAbout Offline
walkAbout  Offline
Germany
Your supposed to have a small amount of pressure in your gas tank on a warm day when you open it, up to 1.5 PSI, your fuel system is a vapor saver and is designed to be under pressure. That way you don't smell gas in your garage or anywhere else.
See the pics, I don't think I get pressure in the gas tank as the tube itself is vented. The small vent tube goes under the car into the brace (don't know the exact word/have another pic to show)
CU
Thomas
Re: Locking gas cap for '70 Challenger [Re: walkAbout] #882412
03/05/13 07:31 PM
03/05/13 07:31 PM
Cincinnati, Ohio
Cincinnati, Ohio
Good point, yours is a 70, non N-95. After that they went to the Vapor Saver system. Good pictures of a 70 setup that uses the "not vented" cap.
Re: Locking gas cap for '70 Challenger [Re: Challenger 1] #882413
03/05/13 08:34 PM
03/05/13 08:34 PM
new york
P
paris401 Offline
paris401  Offline
P
new york
$600 bucks?? if u are worried about gas thievery, buy a gun... and u will have $$$ left in your pocket...
Re: Locking gas cap for '70 Challenger [Re: paris401] #882414
03/11/13 02:29 PM
03/11/13 02:29 PM
Wausau Wisconsin USA North Ame...
radiatorman Offline
radiatorman  Offline
I have one of these I want to use on a car. Got it without a key so I didn't even know if it worked. Took it apart and had a key made. Now that it is put back together it doesn't lock. I don't remember dropping anything or if that is why they sold it. Anyone ever take one of these apart and have some pictures for me to see if I am missing something?
Thanks,
Bob
bobs@glenrayradiators.com
Re: Locking gas cap for '70 Challenger [Re: radiatorman] #882415
03/11/13 06:44 PM
03/11/13 06:44 PM
california
Mr D21 Offline
Mr D21  Offline
california
when you say "it doesn't lock" are you saying that when you install it in the filler neck it doesnt lock closed ??? Or are you saying it doesnt lock when your playing with it in your hands ??
It only locks when installed and you have to have the correct cap for either ECS or CAS systems...
Re: Locking gas cap for '70 Challenger [Re: radiatorman] #882416
03/11/13 07:17 PM
03/11/13 07:17 PM
MD
floyd Offline
floyd  Offline
MD
Here's a pressure vacuum cap from a 71 Challenger. Bob, do the tabs draw inward when you push the button? When its locked, I'm guessing the button doesn't move (and the tabs don't draw inward).
Re: Locking gas cap for '70 Challenger [Re: floyd] #882417
03/11/13 07:21 PM
03/11/13 07:21 PM
MD
floyd Offline
floyd  Offline
MD
another
Re: Locking gas cap for '70 Challenger [Re: floyd] #882418
03/11/13 07:21 PM
03/11/13 07:21 PM
MD
floyd Offline
floyd  Offline
MD
gasket
Re: Locking gas cap for '70 Challenger [Re: floyd] #882419
03/11/13 07:22 PM
03/11/13 07:22 PM
MD
floyd Offline
floyd  Offline
MD
other side of gasket
Re: Locking gas cap for '70 Challenger [Re: floyd] #882420
03/12/13 10:03 AM
03/12/13 10:03 AM
radiatorman Offline
radiatorman  Offline
Ugh, I didn't install and try. I will do this this morning. Thanks guys!!
Bob
Re: Locking gas cap for '70 Challenger [Re: radiatorman] #882421
03/12/13 10:22 AM
03/12/13 10:22 AM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
Thanks,
Bob
Look to see if the tab is broken. Mine wouldn't lock either and found that without this tab in place it doesn't. I had to make a part by hand and now it locks.
Re: Locking gas cap for '70 Challenger [Re: gygeneral] #882422
03/12/13 10:24 AM
03/12/13 10:24 AM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
Another
Re: Locking gas cap for '70 Challenger [Re: gygeneral] #882423
03/12/13 12:37 PM
03/12/13 12:37 PM
radiatorman Offline
radiatorman  Offline
Thanks,
Bob
THANK YOU!! Yes that is broken on mine. I didn't make that out on Bruce's picture.
Bob
Re: Locking gas cap for '70 Challenger [Re: radiatorman] #882424
03/12/13 12:45 PM
03/12/13 12:45 PM
MD
floyd Offline
floyd  Offline
MD
Bob - How hard was it to get a key made? I don't have one for my cap either.
Page 2 of 3 1 2 3
