Cowl Vent Paint Prep #882163
12/16/10 10:08 PM
12/16/10 10:08 PM
Byesville, Ohio
Tomsecks Offline OP
Tomsecks  Offline OP
Byesville, Ohio
Anybody have a good way to prep a cowl vent for paint??? I've tried a couple different things, but haven't found a good way to sand in between the little bars of the vent. One of the last things I've got left to prep, hoping that there's a quick way to clean them up. Let me know what you've done, thanks.
Re: Cowl Vent Paint Prep [Re: Tomsecks] #882164
12/16/10 10:18 PM
12/16/10 10:18 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
That is one of the worst spots to prep. Honestly, I just grab some sand paper and get to work. I have not found an easy way to do it.
Stan
Re: Cowl Vent Paint Prep [Re: Tomsecks] #882165
12/16/10 10:23 PM
12/16/10 10:23 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
Scotch brite pads work well.
Old, tired, and sometimes broke down. Me, not my car...
Re: Cowl Vent Paint Prep [Re: HemiStan] #882166
12/16/10 10:26 PM
12/16/10 10:26 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Sticky backed sandpaper over a popsicle or paint stir stick and floss away.
If you can't find any sticky sandpaper you can staple the paper to the wood.
Re: Cowl Vent Paint Prep [Re: Tomsecks] #882167
12/17/10 09:59 AM
12/17/10 09:59 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Wire wheel on a drill or die grinder. Be sure and wear eye protection.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Cowl Vent Paint Prep [Re: Tomsecks] #882168
12/17/10 11:36 AM
12/17/10 11:36 AM
Ohio, USA
Dr-Dave2 Offline
Dr-Dave2  Offline
Ohio, USA
Make your kids do it!
my daughter has helped me prep 5 allover repaints, getting pretty good at it too.
but seriously the fine wire brush on a drill will get you started, followed by folded over sandpaper then 3M dark red scuff pad and oh-yeah a couple of hours of time
Re: Cowl Vent Paint Prep [Re: MOPARMIKE69] #882169
12/18/10 02:00 AM
12/18/10 02:00 AM
Jacksonville Florida
elitecustombody Offline
How about a 36 grit disc on a grinder?
OP is looking for advice to prep,not strip
Red scuff pads always works just fine
Re: Cowl Vent Paint Prep [Re: Tomsecks] #882170
12/19/10 03:23 AM
12/19/10 03:23 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I will add to remember to clean the area out with high pressure air hose.
At least 5 seperate times, throughly at every angle possible.
That ia a giant trap for crud to wreck a fresh paint job..
BTW,
I used a paint stick with scuffin pads on mine...
Re: Cowl Vent Paint Prep [Re: sthemi] #882171
12/19/10 03:34 AM
12/19/10 03:34 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What do you guys do on the inside of the cowl area and the underside of the cowl? I've got the plastic grill vents on mine so at least I can take them off and get my arm in there but it still looks like a nightmare of a job no matter how I do it.
