70 cuda 4 speed reverse light issue #881822
12/16/10 04:03 PM
12/16/10 04:03 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
im having a problem with the reverse light where it seems that the light on the dash and reverse lights only work when i hit the brakes.i have the correct 2 prong wiring from the trans to the fuse panel and the wire coming out of the harness in the engine bay to the dash light seems to be correct. what im not sure on is how the brake switch ties into the reverse under the dash. any help is very much apprecated.
Re: 70 cuda 4 speed reverse light issue [Re: kingkt] #881823
12/16/10 06:46 PM
12/16/10 06:46 PM
NJ
rth Offline
rth  Offline
NJ
check and clean tail light socket grounds.bad grounds do wacky things.
Re: 70 cuda 4 speed reverse light issue [Re: rth] #881824
12/16/10 09:56 PM
12/16/10 09:56 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
tried that. no change. i wondered if the under dash harness might have something to do with it.... it a 1970 rallye harness from a automatic car.
Re: 70 cuda 4 speed reverse light issue [Re: kingkt] #881825
12/16/10 10:00 PM
12/16/10 10:00 PM
Kirkland, Washington
Pacnorthcuda Offline
First thing I would do is jump the two wires at the tranny, turn on the ignition--light should be on. If it is then the issue is in the switch/tranny, if not its in the wiring circuit.
Re: 70 cuda 4 speed reverse light issue [Re: kingkt] #881826
12/16/10 10:00 PM
12/16/10 10:00 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Let me get this straight- you are using an original auto trans car's harness in your now-manual trans car?
Re: 70 cuda 4 speed reverse light issue [Re: kingkt] #881827
12/16/10 10:10 PM
12/16/10 10:10 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Still sounds like a taillight housing ground issue.
Re: 70 cuda 4 speed reverse light issue [Re: Pacnorthcuda] #881828
12/16/10 10:38 PM
12/16/10 10:38 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
yup.... its the switch. ran the test and had a nice bright light....now where to get one...thank you
Re: 70 cuda 4 speed reverse light issue [Re: kingkt] #881829
12/16/10 11:08 PM
12/16/10 11:08 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Brewer's has them.
Re: 70 cuda 4 speed reverse light issue [Re: kingkt] #881830
12/17/10 09:44 AM
12/17/10 09:44 AM
Morningside, Long Island
scatcity Offline
scatcity  Offline
Still available from your local Chrysler dealer...buy an extra one too..
