Dry Sump Plumbing??? #881623
12/16/10 11:29 AM
12/16/10 11:29 AM
Alexandria, LA
Blucuda413 Offline OP
Alexandria, LA
I'm still studying dry sump systems and there's not a lot of info out there.
If you had a six stage system which means 5 scavage ports where specifically would you plumb those 5 lines. I can see that probably 3 would go to the pan but exactly where and how would the other 2 lines go?? I'm looking at a hemi implementation.
Re: Dry Sump Plumbing??? [Re: Blucuda413] #881624
12/16/10 11:40 AM
12/16/10 11:40 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I run a 4 stage pump 2 in the pan and 1 in the intake
valley... on yours you could run 3 in the pan(I like
to mount dividers in the pan so each line is picking
up right at the front of each divider wall... dividers
are not sealed to the bottom but slow the oil) then
2 up in the valley one front and 1 rear but mine is
a closed valley(no return)... if yours is open I would
put 4 in the pan
EDIT
Run a filter (screen type) on ALL suction lines
to protect the pump if the engine breaks
Re: Dry Sump Plumbing??? [Re: MR_P_BODY] #881625
12/16/10 04:30 PM
12/16/10 04:30 PM
Finland
mafo Offline
mafo  Offline
Finland
I have all four in the pan?
moroso has fittings with built in screens and their web site is very informative
http://www.moroso.com/articles/images/drysump.gif
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: Dry Sump Plumbing??? [Re: mafo] #881626
12/16/10 07:17 PM
12/16/10 07:17 PM
Get-X Offline
Get-X  Offline
Mine too
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Dry Sump Plumbing??? [Re: Blucuda413] #881627
12/16/10 07:42 PM
12/16/10 07:42 PM
Columbus, OH
Ben Holt Offline
Ben Holt  Offline
Columbus, OH
I think your question revolves around where is the last scavenge from?
If you have a 5 stage, you could do 3 in the pan and one in the valley. We usually do that if the valley is sealed off. Or you could just do 4 in the pan.
The 5th stage would be the scavenge out of the reservoir, pressure out to a filter, then into the block.
Hope this helps
Re: Dry Sump Plumbing??? [Re: Ben Holt] #881628
12/16/10 08:04 PM
12/16/10 08:04 PM
Alexandria, LA
Alexandria, LA
Thanks, appreciate the input. I guess my question really is how do you get to the lifter valley, where is the line plumbed etc. How do you get to the oil in the valley?? That's the only area that is fuzzy to me, I guess some pictures would work wonders if anyone has some.
Thanks Guys!!
Re: Dry Sump Plumbing??? [Re: Blucuda413] #881629
12/16/10 08:39 PM
12/16/10 08:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks Guys!!
I have a valley plate on my SB and I drilled a hole
for a bulkhead fitting... the braided line mounts to
the fitting then on the inside I have a tube welded
to the fitting that goes to the back corner to suck
up the oil
Re: Dry Sump Plumbing??? [Re: Blucuda413] #881630
12/16/10 10:02 PM
12/16/10 10:02 PM
AndyF Offline
AndyF  Offline
Well the simple answer is that you put the lines where you need them. A circle track motor might put a line to the passenger side valve cover for example because oil will pile up there. A drag motor might put a line in the back of the valley. A boat motor with the engine mounted backwards will put the lines in yet another location.
Re: Dry Sump Plumbing??? [Re: AndyF] #881631
12/16/10 10:44 PM
12/16/10 10:44 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I have 3 in the pan and one sucking from the cam tunnel sump by the dizzy and cam gears....
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
