back brace #881056
12/15/10 07:30 PM
12/15/10 07:30 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
anyone buy competion engineering back brace it looks like its both braces C9105 http://www.competitionengineering.com/catalog/CategoryDisplay.asp?CatCode=10086 but when you look it up in summit it says sold individually. think this is a set. yes I have brain damage.
Re: back brace [Re: plycuda] #881057
12/15/10 07:35 PM
12/15/10 07:35 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
save ur cash and get the moser one out of summit,unlike comp it will actually fit
Re: back brace [Re: plycuda] #881058
12/15/10 07:37 PM
12/15/10 07:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Both parts are in a set... otherwise if it was only
a side it would ask LEFT or RIGHT(they are different
EDIT
its real easy to make them from 2 X 3 tubing and a set
of dividers and a band saw(I make my own)
Re: back brace [Re: MR_P_BODY] #881059
12/15/10 07:43 PM
12/15/10 07:43 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Not to hijack your thread, but when you weld these in do you have to do it in a jig? I've heard it warps the housing?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: back brace [Re: MR_P_BODY] #881060
12/15/10 07:43 PM
12/15/10 07:43 PM
tboomer Offline
tboomer  Offline
EDIT
There we have it!! Mike is retired witha new shop...I can see it now...Riff-Raff Engineering!! How bout it,Mike!!
Re: back brace [Re: DemonDust] #881061
12/16/10 11:37 AM
12/16/10 11:37 AM
Mo.
racerx Offline
racerx  Offline
Mo.
In my opinion that would be the best way I've weld a couple with the weld a " method and switch to prevent warpage and to seem not to get around it.
Re: back brace [Re: racerx] #881062
12/16/10 11:40 AM
12/16/10 11:40 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
So if I'm reading this correctly you stitch welded an inch at a time and alternated areas? And it still warped the housing?
SDG Motorsports
Re: back brace [Re: DemonDust] #881063
12/16/10 11:44 AM
12/16/10 11:44 AM
Mo.
racerx Offline
racerx  Offline
Mo.
That's correct.and always seems to have to cut the ends off and re weld the backing plates in a jig
Re: back brace [Re: tboomer] #881064
12/16/10 12:12 PM
12/16/10 12:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
EDIT
Been that way for a while... fab work and welding
and working on my cars keeps me going.... I stitch
weld the brace then add the ends
Re: back brace [Re: fishy340] #881065
12/16/10 01:29 PM
12/16/10 01:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Exactly..........mine fit like a glove and is helping to keep my heap together.
Re: back brace [Re: Thumperdart] #881066
12/16/10 02:57 PM
12/16/10 02:57 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Anyone have pics of how they jig up an 8 3/4?
SDG Motorsports
Re: back brace [Re: DemonDust] #881067
12/16/10 03:23 PM
12/16/10 03:23 PM
Cab_Burge Online work
Cab_Burge  Online Work
I know several shops that did more than one 8 3/4 and nine inch Fords back brace by stitch welding 1/2 to 1 inch at a time on the top of the left side first and then did the bottom right side next and switch back and forth letting each side cool for several minutes before coming back to the same side. They used a mig machine(wire welder) I don't know what diameter wire or heat setting but only one of there jobs warped the rear end housing due to getting in a hurry
Re: back brace [Re: Cab_Burge] #881068
12/16/10 05:38 PM
12/16/10 05:38 PM
Maryland
Sick 660r Offline
Sick 660r  Offline
Maryland
If the rear becomes warped what can you do to fix it?
2000 dakota 418 magnum paxton novi 2k T56
Re: back brace [Re: DemonDust] #881069
12/16/10 06:36 PM
12/16/10 06:36 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Yes, but first keep in mind a jig is mainly for ease of welding and to verify proper alignment, no jig will prevent by itself warping.
And if it warps a reasonable amount, first fix is to cut off housing ends, realign, and then reweld carefully.
Re: back brace [Re: Sick 660r] #881070
12/16/10 06:43 PM
12/16/10 06:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
to fix it?
A press and or a torch with a rosebud and a press
Re: back brace [Re: DemonDust] #881071
12/17/10 05:18 AM
12/17/10 05:18 AM
San Diego
formula S Offline
formula S  Offline
San Diego
I used a 10" I-beam about six feet long and a piece of 3/4"x 3"x 6' flat bar to make my fixture. I took the flat bar and set it on top of the I-beam and welded it so it was 3" high, then I set the housing face down, you will have to notch it common to the gasket surface. Next you need to clamp it to the fixture then tack it in several places, now remove your clamps and get your back brace, fit it, tack it, and weld it, no need to stitch it ,just let it cool in the fixture before you remove it, it wont pull if you do it this way
Re: back brace [Re: jcc] #881072
12/17/10 05:38 AM
12/17/10 05:38 AM
San Diego
formula S Offline
formula S  Offline
San Diego
The fixture I made works really well and prevents any warping at all. I have seen housings that were warped, the axles wont go in straight because the bearing dosent line up with the housing, not the case with this method. The I-beam and flat bar are really heavy duty and dont see any heat, so no fixture warpage.
Re: back brace [Re: racerx] #881073
12/17/10 02:56 PM
12/17/10 02:56 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Most people don't have a jig. I didn't when I did my brothers. I did and inch or 2 at a time and moved around. No warpage at all.
Re: back brace [Re: BobR] #881074
12/18/10 12:51 PM
12/18/10 12:51 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
any pics of the premade or homemade
Re: back brace [Re: BobR] #881075
12/18/10 12:56 PM
12/18/10 12:56 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I have done more than a few, if the axels are in they kind of act like a jig imo. I fully let the small welds cool before doing more. they may not be perfect if they were put on a jig but they have never caused any problems.
