straight vs. split pattern cams
#880733
12/15/10 01:04 PM
12/15/10 01:04 PM
Posts: 383 Essex, Ont., Canada
Fishmarket
Essex, Ont., Canada
Can someone explain when and why it would be advantaageous to use a split pattern cam with more exhaust duration, and when a greater exhaust duration would start to be detremental? I can see using a split on an engine breathing through exhaust manifolds but what if your heads are ported and you have a free flowing header/exhaust set up? Can too much exhaust duration hurt power output?
1972 Plymouth Cuda 340 4 speed
1971 Plymouth Road Runner 383 Auto
1970 Plymouth Duster /6 Auto
Re: straight vs. split pattern cams
[Re: Fishmarket]
#880734
12/15/10 01:36 PM
12/15/10 01:36 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Testing has show for a given intake profile they will give a little more power with a longer exhaust duration. so lets say a standard 236/236 @ .050 110 LSA cam changing it to a 236/244 @ .050 cam will give a little more power and not effect the drive ability from where it is. the norm seems to be 6 to 10 more on the exhaust to get rid of that expanded hot exhaust charge.
[Re: Dodgem]
#880735
12/15/10 02:11 PM
12/15/10 02:11 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
The magic number, here, is 75%. You want your exhaust port to flow @ 75% of your intake port. Most stock heads (especially BB mopars) don't do this, so cam manufacturers figured they can compensate for the heads shortcomings by extending the duration on the exhaust side.
What has happened now, is that split pattern cams have just become the norm, and the general public percieves they are getting a better engineered product with varying #'s on the card (not really knowing why)
Most good aftermarket heads do support the 75% number, however.
The key when choosing a cam is knowing what your heads will flow, and complimenting that curve with the cam. With good heads that flow properly, there is a strong case to be made that you'll maximize the power available from a given duration and lift spec. with a square pattern cam. Your intake, carburetor, and header selection also plays a role here.
I conferred with Member, Jeff Patterson, when choosing my cam, and we both agreed that my combo seemed to call for a square pattern cam, so that's what we dialed up from Engle.
[Re: StealthWedge67]
#880736
12/15/10 02:17 PM
12/15/10 02:17 PM
Posts: 5,080 organ
maximum entropy
organ
WHAT HE SAID.
[Re: Dodgem]
#880737
12/15/10 02:32 PM
12/15/10 02:32 PM
Posts: 1,200 UK
602heavy
UK
Opinions are just that , here's mine FWIW. Running too much exhaust duration with low compression engines just kills torque , exhaust valve requires a later opening to take advantage of later peak pressure associated with low compression ratios , opening exhaust valve to early won't give the expanding gasses enough time/leverage to push on piston , using a faster lobe can help regards pumping lossess , sometimes a higher ratio rocker arm on exhaust can help when going shorter on exhaust duration................the other problem with long duration exhaust lobes is the overlap period , once the piston moves away from TDC on intake stroke it's drawing on both intake & exhaust port , any spent gasses left in the exhaust port will be sucked into the cylinder along with fuel'air from intake port , the longer the exhaust valve is held open on intake stroke the more contaminated the charge will be , this is the reason tighter lobe centres produce less vaccume & run pretty rough @ idle , the cleaner the intake charge the more power the engine will produce. Using restricted exhaust manifolds along with later closing exhaust valves (longer overlap period) makes matters worse on street engines that only spin to around 3500/4000 rpm , unless that exhaust can scavenge intake charge will be contaminated.......why is it advancing intake centreline makes more torque low down? , LESS CONTAMINATION......all you guys using split patterns (low comp) go loosen lash on exhaust valve & notice the motor pick up , will idle a bunch nicer too. Just my , feel free to bash the hell out of it.
[Re: Fishmarket]
#880738
12/15/10 03:17 PM
12/15/10 03:17 PM
BradH
Whose testing? I've seen some that show that the proper single-pattern cam will provide more power through the entire range. So, who do you believe?
Sorry, there is NO MAGIC NUMBER. That "75%" rule is outdated.
Opinions are just that...
I won't argue that point.
[Re: 602heavy]
#880741
12/15/10 04:12 PM
12/15/10 04:12 PM
BradH
Hey Budget , what does 'do not feed the troll' mean?
It means I'm in kind of a crappy mood and this is just the sort of thread that could cause me to post of bunch of smart@ss comments in my replies.
[Re: BradH]
#880744
12/15/10 04:35 PM
12/15/10 04:35 PM
Posts: 1,200 UK
602heavy
UK
It means I'm in kind of a crappy mood and this is just the sort of thread that could cause me to post of bunch of [Email]smart@ss[/Email] comments in my replies.
I wanna know who's the TROLL.
[Re: 602heavy]
#880745
12/15/10 05:13 PM
12/15/10 05:13 PM
BradH
That refers to ME. Although I tell my kids my parenting role model is Shrek and he's an ogre, not a troll.
Re: straight vs. split pattern cams *DELETED*
[Re: Fishmarket]
#880747
12/15/10 09:39 PM
12/15/10 09:39 PM
Posts: 4,211 New York
polyspheric
New York
Post deleted by polyspheric
Boffin Emeritus
[Re: BradH]
#880748
12/15/10 11:46 PM
12/15/10 11:46 PM
StealthWedge67
Puyallup, WA
Well, if opinions are "just that", then I'll consider yours to be the low side of the analogy. You've certainly provided plenty of facts to support your rant, there..... (oh, maybe not) Until you can show me actual numbers that say the 75% rule is untrue, I'm going to consider your opinion completely arbitrary. Perhaps I should have called it a "rule of thumb", not a "magic number", this I'll concede. But the facts remain. This number is based on the physics of volumetric transfer. I don't think these mathematical equations "expire" with time. Why does just about every internal combustion head ever manufactured feature an exhaust valve approx. 75% of the intake? You may really mean to point out that this rule of thumb isn't foolproof every time??. To which I'd still ask you to come up with a fact based equation that outweighs it. Bottom line, heated exhaust gas needs approx. 75% of the volumetric space to travel at the same velocity as the cooler, wetted intake charge. If a heads flow capability doesn't support that mathematical certainty, then adjusting the exhaust valve duration to compensate has become the accepted path that cam manufacturers have followed.
[Re: Sport440]
#880750
12/15/10 11:59 PM
12/15/10 11:59 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
what do the FAST class guys run?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#880751
12/16/10 12:08 AM
12/16/10 12:08 AM
StealthWedge67
Puyallup, WA
According to the writeup on Joel Nystrom's 67 GTX in MuscleCar Review last month, He reportedly runs heads that have been custom ported to flow 420 on the intake, and 315 on the exhaust.... (at this point I would ask you to do the math on that relationship).
The same writeup notes that he employs a camshaft that features 4% more duration on the exhaust side. This makes sense, since his hemi runs 1250 cfm worth of dual AFB on the intake side, but stock exhaust manifolds on the exhaust side.
#880752
12/16/10 12:20 AM
12/16/10 12:20 AM
sixpackgut
Charleston
420/315 what does a head done for super stock flow?
