99' Durango overheating
#880610
12/15/10 09:42 AM
12/15/10 09:42 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Drove it home from work yesterday, heat worked fine. Run in the house for a minute, come back out and head to basketball practice. The heater starts blowing real cold air, I look at the temp gauge and it was at 230-240. Nursed it back home, for a few seconds it started blowing hot air and the temp went down, but immediately went back up and blew cold air again. I just put a new thermostat in a few weeks ago. Could the thermostat be sticking closed? Water pump going bad? This is a 5.2 litre V8 auto.
Re: 99' Durango overheating
[Re: RapidRobert]
#880613
12/15/10 12:01 PM
12/15/10 12:01 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
With no heat and high coolant temp Id say the stat might be bad.When I bought my 99 I drove about a mile to get gas.It was at 230 real quick.Just because the stat was new dont mean it cant be bad.Mine was the stat and the truck only had 18K on it when I got it.Rocky
Chrysler Firepower
[Re: ProSport]
#880616
12/15/10 11:05 PM
12/15/10 11:05 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Do you have the optional rear heat? I had the coolant go low in my 2003. The rear heater core is higher that most of the coolant system. Air can accumulate in there and it is a b*@& to get out. The FSM has a procedure but it did not work on mine. This was with a 4.7 so it may not be the same problem. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: gtx6970]
#880618
12/16/10 12:22 AM
12/16/10 12:22 AM
Posts: 1,411 Tallmadge, Ohio
Paul_B
Tallmadge, Ohio
high engine temps and lower heater output 99% of time = low on coolant +/or air in the system
[Re: LABBINSKI]
#880621
12/16/10 01:13 PM
12/16/10 01:13 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
If you find the resovoir full but still have the same problem it is air in the system, you may want to replace the cap as it is probably not sealing the air out when it cools and is supposed to draw a vaccume to pull the coolant into the system.
