5" dump pipe into 2x3" pipes question. #880597
12/15/10 07:33 AM
12/15/10 07:33 AM
Australia
gg408 Offline OP
gg408  Offline OP
Australia
Due to lack of room in my 67 Valiant I was wondering if going from 5" dump pipe to twin 3" pipes will cause a lot of back preasure/restriction.
S480 BW on 410ci W2 headed SB Mopar.
Cheers gg408
Re: 5" dump pipe into 2x3" pipes question. [Re: gg408] #880598
12/15/10 01:47 PM
12/15/10 01:47 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
A three inch pipe has an area of 28 square inches. Two of them have 56 square inches. A five inch pipe has an area of 78 inches.
Maybe you could use three 3" pipes?
- Stu Harmon
Re: 5" dump pipe into 2x3" pipes question. [Re: feets] #880599
12/15/10 02:13 PM
12/15/10 02:13 PM
mid-mich
turboplymouth Offline
mid-mich
Actually it's radius sq. x Pi, but you probably know that
So more like 19 sq. inches for a 5" pipe and 14 for two 3" pipes. So its like a 4 1/4" pipe or so.
I did my dp like this for the same reason as you.
'72 Scamp, 3500#, 440, S400, blowthrough, meth. inj. 9.78 @ 139 so far at 12 psi, 11.00 @ 131 on real street tires.
Re: 5" dump pipe into 2x3" pipes question. [Re: feets] #880600
12/15/10 02:16 PM
12/15/10 02:16 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Ummm... pi r^2
3" pipe
1.5 x 1.5 = 2.25 x 3.14 = 7.06 x 2 pipes = 14.13 sq in
5" pipe
2.5 x 2.5 = 6.25 x 3.14 = 19.63 sq in.
So there is some reduction, but not that much.. 3.5" pipe is basically a wash, 3" is a little small, but really do you need a 5" pipe for an 80mm turbo? Probably not...
Re: 5" dump pipe into 2x3" pipes question. [Re: dizuster] #880601
12/15/10 02:25 PM
12/15/10 02:25 PM
mid-mich
mid-mich
Seems I remember seeing some tests showing that those turbos reduced down to 4" did'nt hurt power. I know there are guys making big power that way.
Re: 5" dump pipe into 2x3" pipes question. [Re: dizuster] #880602
12/15/10 02:38 PM
12/15/10 02:38 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
"but really do you need a 5" pipe for an 80mm turbo?"
My thoughts exactly!
Re: 5" dump pipe into 2x3" pipes question. [Re: TheOtherDodge] #880603
12/15/10 03:10 PM
12/15/10 03:10 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
I saw no gain going from 4" to 5" on my large frame 101. I put the 4" back on because it fit so much better. but I'm not pushing it to the absolute limits. No need for 5" on an s480 anyways.
One day I will have something cool here.
Re: 5" dump pipe into 2x3" pipes question. [Re: turboplymouth] #880604
12/15/10 03:32 PM
12/15/10 03:32 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I thought it was A=pi*r2 but checked online to be sure. This is what I found:
The radius of a circle is 3 inches. What is the area?
Solution:
= 3.14 · (3 in) · (3 in)
= 3.14 · (9 in2)
= 28.26 in2
Now, if you're an idiot like me, you see 3" radius and go with it. Nevermind the fact that you're working with a 3 diameter.
So, if he dumps the 10" pipe into two 6" pipes he'll need a third pipe.
- Stu Harmon
Re: 5" dump pipe into 2x3" pipes question. [Re: feets] #880605
12/15/10 06:02 PM
12/15/10 06:02 PM
mid-mich
mid-mich
Re: 5" dump pipe into 2x3" pipes question. [Re: turboplymouth] #880606
12/16/10 06:58 AM
12/16/10 06:58 AM
Australia
gg408 Offline OP
gg408  Offline OP
Australia
Ok so if I go for a 4 " pipe how close to the turbo outlet should the reducer be and do I need to have a long reducing cone and if so what would the min length be?
This is what I have now and am trying to get the 3" pipes to run up next to the eng so they dont hang to low under the k-member.
Cheers gg408
Re: 5" dump pipe into 2x3" pipes question. [Re: gg408] #880607
12/16/10 07:36 AM
12/16/10 07:36 AM
Australia
gg408 Offline OP
gg408  Offline OP
Australia
Another 1
Re: 5" dump pipe into 2x3" pipes question. [Re: gg408] #880608
12/16/10 07:38 AM
12/16/10 07:38 AM
Australia
gg408 Offline OP
gg408  Offline OP
Australia
And another 1
Re: 5" dump pipe into 2x3" pipes question. [Re: gg408] #880609
12/16/10 05:09 PM
12/16/10 05:09 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
It would be best to have the reduction after the initial turn. The air will begin losing rotation as soon as it leaves the turbine but that first turn is still very turbulent.
- Stu Harmon
