Top end oiling
#880436
12/15/10 12:42 AM
12/15/10 12:42 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Is there a way, test, etc to determine if you have sufficient oil flow to the top of the motor? I think I have sufficient flow to the top, but I dont know that for sure. I have plenty of oil to the tips of the rockers, but not to the cups. Been asking around and nobody has an answer on how to determine sufficient flow.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Top end oiling
[Re: Von]
#880437
12/15/10 12:49 AM
12/15/10 12:49 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You could use a old valve cover and cut the top off of it and silicone a clean plastic on it and watch it at some revs
Re: Top end oiling
[Re: MR_P_BODY]
#880438
12/15/10 12:53 AM
12/15/10 12:53 AM
Von
NE Oklahoma
Might have to do that!!
I thought of another question. At rest with the motor set to oil the top, should oil be squirting out of the rocker and running down the adjuster to the cup area? As it sits now, with a drill on the pump, plenty of oil is running out of the feed hole for the cup, but none of it hits the adjuster. The tip on the other hand gets plenty of oil. Ive checked it with the motor running and very little to none gets to the cup, tips once again get plenty.
Re: Top end oiling
[Re: Von]
#880439
12/15/10 02:00 AM
12/15/10 02:00 AM
Posts: 8,879 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
First you have to make up your mind ... is the cup getting oil or isn't it.
The oil is used to "lube" the adjuster/cup - shouldn't need much. On the other hand, the oil is used to "cool" the spring. The more the better! Stands to reason more should be directed at the rocker tip/spring.
Also keep in mind that most of the oiling is achieved with "splash" ... the squirt hits the side of the valve cover and then splashes back onto the cup, etc..
Harland Sharps have no oiling directed at the roller tips or springs. Makes ya wonder !
Re: Top end oiling
[Re: Stanton]
#880440
12/15/10 02:31 AM
12/15/10 02:31 AM
Von
NE Oklahoma
Plenty of oil coming out of the feed hole for the cup area....none of it gets to the cup...So, ya my mind is made up, not getting any oil to the cup.....
And as I said above, motor running or not, no oil gets to the cup.....
Further, I have a set of stock adjustables and they get plenty of oil to the cup with the motor running. The oil swirls around the pushrod very nicely.
So based on the above, it would appear that I have sufficient volume..since the ductile rockers get plenty of oil.
But, how do you KNOW that you have sufficient volume? Ive had 2 other sets of rockers on this motor and neither set had sufficient oil to the cups....
Re: Top end oiling
[Re: Von]
#880441
12/15/10 02:49 AM
12/15/10 02:49 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Is your adjuster screws hollow? Is the shafts banana grooved? This is where we have problems with after market Hemi rockers. (some) burn up in street use, while the same setup lasts for ever in race conditions. Id say that with increased engine rpm plenty of oil flying around for the adjusters. But you can look into the hollow adjusters, increase or redirect the size of the oil passage. Ad the banana groove rocker shafts. Take the cam and groove the correct cam bearings, IIRC #4 with a .050x.050 oil groove. You cold drill and tap the blocks valley area and just provide full time oiling that way. A high volume oil pump will provide more oil (everywhere) at idle and just off idle Just some thoughts.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: Top end oiling
[Re: Von]
#880443
12/15/10 10:34 AM
12/15/10 10:34 AM
MR_P_BODY
Also you could use your priming tool to spin the pump and watch... turn the crank over slowly while priming it
Re: Top end oiling, Update...One question..
[Re: BradH]
#880445
12/19/10 12:58 AM
12/19/10 12:58 AM
Von
NE Oklahoma
I swapped shafts to a pair that has been banana grooved. I have a major stream of oil coming out of both the front and back of the rocker.
So, my question is, at rest with a drill running the pump, should oil be hitting the adjuster/screw?
As it is, no oil hits the screw, just runs down the back of the rocker
[Re: MR_P_BODY]
#880447
12/19/10 02:26 AM
12/19/10 02:26 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
This would lead me to believe you're lacking pressure. And since volume equals pressure ...
[Re: MR_P_BODY]
#880448
12/19/10 02:30 AM
12/19/10 02:30 AM
Von
NE Oklahoma
[ See what rpm your spinning the priming tool then you can relate that to the cam speed (1/2 of the crank) but it should be hitting it I would think EDIT better yet just look to see what the pressure is and if its above about 20 it should be hitting it because that would be pretty close for idle
The pressure is close to 60, about what it holds at idle, give or take a little.
[Re: Stanton]
#880449
12/19/10 02:33 AM
12/19/10 02:33 AM
Von
NE Oklahoma
See above. No problem with pressure. Dont think you are correct that volume equals pressure....
