Holly carb - Diaphram #87982
07/13/08 03:18 PM
07/13/08 03:18 PM
michigan
440whiteboy Offline OP
michigan
with my street avenger 750
behind the choke on the pass side -
its listed in the holly trick rebuild parts sheet #110 sec. diaphram & rod assembly.
does this diaphram look normal?
They only see Stars...
when hit by a Mopar!
Re: Holly carb - Diaphram [Re: 440whiteboy] #87983
07/13/08 05:35 PM
07/13/08 05:35 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Nope, looks rough with too much swelling/expansion...should fit in there with consistant play in the diaphram...Make sure the screws don't catch the rubber when tightening the new one...
Re: Holly carb - Diaphram [Re: screamindriver] #87984
07/14/08 08:46 AM
07/14/08 08:46 AM
michigan
michigan
hey thanks -
something told me this wasn't right -
you can see the first guy who put this one on tore the one corner. thanks for the tip!
will get a new one -
