Re: refinishing a k-member
[Re: OzHemi]
#879743
12/14/10 01:13 PM
12/14/10 01:13 PM
Posts: 5,048 Atlanta Indiana
Dave Watt
Atlanta Indiana
Powder coating out your way is sure cheaper than here
It must be, black is very cheap to do locally. Steel wheels are $25 each. 2 full length bumper reinforcements for my Duster, $20 for the pair. Another place did my K-frame, motor mounts, trans crossmember, 2 pulleys, master cylinder support plate, and Road Runner bumper brackets all for $250, but that was quite a few years ago. Find a place that does a lot of producton powder coating because black is always on hand and they will just throw your stuff in the same batch.
[Re: Dave Watt]
#879746
12/14/10 03:40 PM
12/14/10 03:40 PM
Posts: 732 eastern,Ky
70RT Charger
eastern,Ky
My friend just done his k-frame and rear end with the Rustoleum semi-gloss back and I cant believe how beautiful it turned out.He done a test spray on an old fender to check the durability of it and it shocked me how tough it was.Its not as tough as the exterme chassis black but about like the old chassis black.For $10 a quart I thought it was a steal.
[Re: 70RT Charger]
#879747
12/15/10 01:47 AM
12/15/10 01:47 AM
Posts: 712 California
BigDaddy440
California
Having mine powder coated in "Bk-05" Semi-Gloss black as week speak. Should be done on Friday. I'll post pics.
Blacks are inexpensive. The shop I use allows me to run my parts with big jobs they do for companies....so the cost is very reasonable. The downside is depending on the color I want, I sometimes have to wait several weeks until they run that color.
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: BigDaddy440]
#879748
12/15/10 02:15 AM
12/15/10 02:15 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
You deal with Vince over @ BWM???
[Re: 70B5Cuda]
#879750
12/17/10 08:49 PM
12/17/10 08:49 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
I don't think there is anything wrong with making sure it's nice and clean and then hitting it with a good coat of primer and gloss black, BUT I had mine sand blasted and powdercoated 'cause I'm lazy. The powdercoating is tougher and will last longer, but a good coat of paint is better than what the factory did and most cars aren't used as all weather daily drivers so it doesn't really matter all that much.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: 70B5Cuda]
#879751
12/17/10 08:54 PM
12/17/10 08:54 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Here is what a freshly sandblasted K frame looks like after I hit it with Eastwood extreme chassis black for what it's worth... ![](/ubbthreads/images/graemlins/thumbs.gif)
(When this stuff dries, it's like a rock!)
OZ-is that the high gloss in the can version?
It's the normal semi-gloss/satin in a spray can stuff. ![](/ubbthreads/images/graemlins/thumbs.gif)
