How much power will this combo get me
#879670
12/14/10 10:11 AM
12/14/10 10:11 AM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
366" small block, 0 deck, 12 to 1 comp. KB 190 pistons, Comp 305H cam 253 @ 50 5.25 lift (about 5.65 with my 1.6 rollers. Ported 2.02/ 1.60 J heads, Eddie air gap. How much difference would a set of RHS heads make. ![](http://i711.photobucket.com/albums/ww114/DragDart360/32010060.jpg)
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: How much power will this combo get me
[Re: Cab_Burge]
#879676
12/15/10 12:14 AM
12/15/10 12:14 AM
DragDart360
South Jersey, NJ
I can get a set of Eddys for a 340 (open Chamber?) used for a good price but the KB web site says these pistons (KB190) won't work with the Eddy heads. I have all this stuff on hand except the Eddy heads. Can they be made to work at a reasonable cost?
[Re: DragDart360]
#879678
12/15/10 12:33 AM
12/15/10 12:33 AM
Posts: 382 Roseville MN
72swgnr
Roseville MN
I have the KB 191 pistons and my RHS closed chambered heads should be here in a few weeks. I was told by the techs that milling the dome off the pistons was acceptable to make closed chambered heads work. Also depending on the dome you MIGHT beable to just use a thicker head gasket.
[Re: 72swgnr]
#879679
12/15/10 12:57 AM
12/15/10 12:57 AM
Posts: 1,064 Tennessee
727builder
Tennessee
Built a guy in florida a 360/904 for his 69 valiant. He got some low 7.0s in the 1/8 shifting at 6600. That was thru the mufflers. His is a 30 over 360 with the kb191 pistons, comp cams 555 solid lift cam, Ported j-heads, Victor jr intake w/750 dp. 904 with a tight 8" converter. Weighs around 3100lbs with him in it. I know i can get some 6.80's with a little looser converter and some tuning.
[Re: 727builder]
#879680
12/15/10 01:20 AM
12/15/10 01:20 AM
Posts: 9,146 Now - Port Orange,Fla. Former...
MIKES_DUSTER
Thats almost the same combo I have except I have a .570 roller cam,M-1 intake,850 dp and a 727 in my duster that weighs 3200 with me.
[Re: goldmember]
#879682
12/15/10 03:56 AM
12/15/10 03:56 AM
Posts: 11,688 W. Kentucky
justinp61
W. Kentucky
While I agree that a WELL ported set of Eddies should run better,I'd stick with a good set of factory heads(ported) over a hack or stock eddie. I see few eddie combo's at the track that impress.
What is impressive? ET? Mph? ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: justinp61]
#879683
12/15/10 05:31 AM
12/15/10 05:31 AM
Posts: 6,151 Melbourne , Australia
LA360
With either head you will need to mill the quench dome on the KB190 pistons. How much Carb are you running?
Alan Jones
[Re: goldmember]
#879684
12/15/10 09:21 AM
12/15/10 09:21 AM
Quicktree
problem with that is factory heads are prone to cracking and will cost about the same to port them. and I seen a 9.76 that was pretty impressive to me out of a set of indy/brocks at gville recently. I would go eddy all the way, only iron head I would use would be the RHS ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Quicktree]
#879685
12/15/10 10:04 AM
12/15/10 10:04 AM
DragDart360
South Jersey, NJ
I'm running a 750 Dominator, Plan to convert it to E-85 so I can run the higher compression
[Re: DragDart360]
#879687
12/15/10 02:16 PM
12/15/10 02:16 PM
Posts: 2,578 sweden
1Fast340
sweden
i have a set of openchamber edelbrock340 heads and i cant realy see a reason why a piston for a stock non closed chamberhead wouldnt work the point with the open chamber 340edelbrock heads is that you can have a fairly good set of heads on a shortblock without changing your "stock type" popup pistons ,but im not sure on what kind of diference there is betwen the KB pistons and a stock 340piston
