SB moroso elect water pump #879096
12/13/10 06:14 PM
12/13/10 06:14 PM
Montgomery, Texas
O
OneRunSon Offline OP
O
Montgomery, Texas
is anyone using moroso's elect. water pump #63565 for smallblock on the street? if so is cooling sufficent? really like how they look and want to run elect. pump on my street/strip build. thanks
Re: SB moroso elect water pump [Re: OneRunSon] #879097
12/13/10 06:57 PM
12/13/10 06:57 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i have one on a siam bore beast,and it keeps her nice and cool
Re: SB moroso elect water pump [Re: OneRunSon] #879098
12/13/10 06:58 PM
12/13/10 06:58 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I have a customer that is running that pump on a 408 that is hardblocked. He doesnt drive it to work everyday and 100 miles to grannys house every weekend, but it does fine bombing around the car cruises etc. I dont think you would want it as a daily driver/cruising all weekend type of pump. Its a nice looking piece however.
RIP Monte Smith
Re: SB moroso elect water pump [Re: CompWedgeEngines] #879099
12/13/10 08:56 PM
12/13/10 08:56 PM
Montgomery, Texas
O
O
Montgomery, Texas
andy & todd, thanks for the info thats what i needed to here. street use will only be short, local hangout,cruise & soda shop then the dragstrip
Re: SB moroso elect water pump [Re: OneRunSon] #879100
12/13/10 09:39 PM
12/13/10 09:39 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
no problem,ryanj made my switch from a csr i had,moroso is soooooo much easier to install,plus if u ever want to add a denso alt or a vac pump it all works great with the moroso water pump..like a 3 pc set..no special stuff..all stuff to add is sold from moroso!
Re: SB moroso elect water pump [Re: fishy340] #879101
12/14/10 07:32 PM
12/14/10 07:32 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Any pics guys??? What are you guys running for a T-Stat and is there any mods done to that T-Stat??
Re: SB moroso elect water pump [Re: MIKES_DUSTER] #879102
12/14/10 07:46 PM
12/14/10 07:46 PM
Maryland
Sick 660r Offline
Sick 660r  Offline
Maryland
Im also interested in pics if possible.
2000 dakota 418 magnum paxton novi 2k T56
Re: SB moroso elect water pump [Re: Sick 660r] #879103
12/14/10 07:53 PM
12/14/10 07:53 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
what kind of partnumbers would that be? intrested in this sick of "customized brackets" from the 80īs that didnt even work with the stock pump..
dont have it installed yet but just tell me what you want a pic of on the pump and i will take some
what kind of pics? got one lying around here not installed yet
Re: SB moroso elect water pump [Re: 1Fast340] #879104
12/14/10 08:00 PM
12/14/10 08:00 PM
Maryland
Sick 660r Offline
Sick 660r  Offline
Maryland
Im looking on the website and I cant figure out how you use a radiator. Sorry for the stupid question lol
Re: SB moroso elect water pump [Re: 1Fast340] #879105
12/14/10 08:08 PM
12/14/10 08:08 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Here is pic of the Moroso pump W/ the moroso bracket for vacuum pump made fr that pump/SB Mopar. This motor I also used the moroso bracket kit to hold the alternator on pass said but I don't have any pics of that mounted. We did'nt run mount/alt on dyno...
Re: SB moroso elect water pump [Re: RyanJ] #879106
12/14/10 08:14 PM
12/14/10 08:14 PM
I have the same pump but mine is blue not black. I bought mine a few yrs back,is that why?? My 340 always ran hot,dont know why?? Hopefully my new 360 will be better.
Re: SB moroso elect water pump [Re: MIKES_DUSTER] #879107
12/14/10 09:01 PM
12/14/10 09:01 PM
Syracuse,NY
Syracuse,NY
No special mods what so ever...here is a simple straight forward pump shot. This car ran a standard alt. and factory steering....50 street/ 50 strip kinda car.
RIP Monte Smith
Re: SB moroso elect water pump [Re: RyanJ] #879108
12/14/10 11:40 PM
12/14/10 11:40 PM
Renton Washington
Triple Threat Offline
Renton Washington
Ryan, Is that Moroso pump just painted black instead of blue?
And secondly is the Moroso your water pump of choice? Over Meziere and CSR? Specifically on a street strip car with just an alternator, no PS or vacuum pump. I'm in the market for one. Non Siamese R block with Indy heads if it matters.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: SB moroso elect water pump [Re: Triple Threat] #879109
12/14/10 11:52 PM
12/14/10 11:52 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
No, the older 1st generation ones were Blue, the last 4 or 5 I've bought in last year were all black.
The moroso is the shortest of all of them by far, alot fo customers complain about the CSR & Mezziere hitting their radiator/fan & like the shortness of teh moroso. Also the moros makes usuing accessory brackets off of the front bolt holes alot easier as well as has better belt clearance. The "leg style" CSR/Mezziere like to interfere with stock location alternators.
Personally my favorite of all of them is the Mezziere... But I use alot of the morosos & some CSRs. The Mezziere is most $ so usually they get nixed in favor of a cheaper pump by customer. The CSR comes with the timing cover block off plate the Mezziere does not... & obviously the moroso has it built in to the design.
I'll just say my personal W9 motor has Mezziere on it & I'm doing a new W8 motor for good friend of mine here in State College, who I'm treating his motor like it was my own & it is getting a Mezziere. So.... you can read into that what you want. The Moroso just makes mounting accessories easier & it is cheapest of the 3.
Re: SB moroso elect water pump [Re: RyanJ] #879110
12/15/10 10:10 AM
12/15/10 10:10 AM
Syracuse,NY
Syracuse,NY
I too like the Meziere as my favorite. The Moroso,like Ryan says is nice, neat, priced better and they do make the nice accessory mounts. Makes it easy. That being said, I've had to replace several Moroso motors ( both blue and black) and havent ever had one on the Meziere, either big or small block.
RIP Monte Smith
Re: SB moroso elect water pump [Re: CompWedgeEngines] #879111
12/15/10 11:27 AM
12/15/10 11:27 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I have a CSI pump and when I bought my Moroso vacuum pump and Moroso bracket I could not figure out how to use the bracket. I ended up modifying the bracket and mounting it low on the passenger side. It would have worked fine with the Moroso water pump.
Re: SB moroso elect water pump [Re: Sick 660r] #879112
12/15/10 07:25 PM
12/15/10 07:25 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
lmao thats because the nipple which is 1 3/4 is not screwed on the motor pictures you see..
Re: SB moroso elect water pump [Re: fishy340] #879113
12/18/10 03:14 PM
12/18/10 03:14 PM
tn
r69cuda Offline
r69cuda  Offline
tn
Can you run an alternator using the stock brackets without the belt rubbing on the bottom of the motor or water inlet? Thanks, Mark
Re: SB moroso elect water pump [Re: r69cuda] #879114
12/21/10 02:55 PM
12/21/10 02:55 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Bump
I would like to know as well.
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: SB moroso elect water pump [Re: Plumb Wired] #879115
12/21/10 03:09 PM
12/21/10 03:09 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
not mine but a pic
