Offenhauser 5186
#879008
12/13/10 03:49 PM
12/13/10 03:49 PM
Posts: 10,948 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
I have an opportunity to get an Offenhauser 5186 dual quad intake pretty cheap. I am contemplating putting it on my 451 stroker motor with stock 451 heads (2.02/1.81 Roller rocker) Just curious if this would be enough intake for my combo or if anyone has experience with it. I was figuring on going with an Eddy RPM but the cool factor would be way up with dual quads and I could do it pretty cheap.
Opinions?
I’m listening.
Re: Offenhauser 5186
[Re: RapidRobert]
#879010
12/13/10 06:02 PM
12/13/10 06:02 PM
Big Bad Bee
Spokane Valley, WA
One site describes it as a split single plane. I was a little concerned about runner size but I love low end torque and it seems like it would do well.
I’m listening.
[Re: HYPER8oSoNic]
#879012
01/19/11 03:22 AM
01/19/11 03:22 AM
Big Bad Bee
Spokane Valley, WA
I ended up missing that intake by a couple hours but there are plenty of them out there. I still like the idea of putting that on my 451 stroker but I don't want to go poor building a dual carb setup!
I’m listening.
[Re: Big Bad Bee]
#879013
01/19/11 03:41 AM
01/19/11 03:41 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Opinions?
Are you sure that your valve sizes are right? 2.02 valves in a big block? Also, the stock heads on 76-78 400/440 engines were '452 castings.
[Re: Kern Dog]
#879014
01/19/11 08:09 AM
01/19/11 08:09 AM
Posts: 4,796 Holland MI Ottawa
2boltmain
Holland MI Ottawa
It is a single plane. I will run the 273/318 unit on a future 360 build. The consensus (facts) are that a Performer RPM and a Holley carb will perform better and make more power. Myself (like you) am choosing the cool factor over best performing set up. The best underhood dual quad manifolds are the Edelbrocks but they never made one for the low deck.
Keep old mopars alive.
[Re: 2boltmain]
#879015
01/19/11 11:59 AM
01/19/11 11:59 AM
Big Bad Bee
Spokane Valley, WA
Greg, The heads were off a 440 race engine that a high school shop class built. I think the whole thing ran on the dyno for about 10 minutes before the bottom end on the thing went "BOOM!" I am the benefactor... I think the valves are okay. Oh, Sorry on the typo. Intake 2.14
I’m listening.
[Re: Big Bad Bee]
#879018
01/20/11 04:13 AM
01/20/11 04:13 AM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
I have had good luck with the Edlebrock 2x4 intake and carbs on friends project cars, and they definitely increase the "wow" factor when the hood is opened. I found one a little rarer - a Weiand Max Wedge port 2x4 low rise intake. I think it was from around 1964-65. Thinking of modifying it to use on my twin turbo EFI motor.
[Re: ProStDodge]
#879021
01/20/11 12:00 PM
01/20/11 12:00 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
I have both the max wedge and RB version of these intakes. I have only used the RB version in a Dart and in the old FED digger. It worked better than a sorted Holley and SD intake at full throttle. That was likely due to using 2 750 Edelbrocks. It was fun on the Dart. I used 2 392 Hemi cheater carbs.
The RB intake was worked on buy an old school shop and flowed. It was matched up to a special high dollar set of 906 heads. At first he laughed at the thought of using that intake. After the work he commented on being very surprised about how well it flowed.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: dvw]
#879022
01/20/11 12:07 PM
01/20/11 12:07 PM
Big Bad Bee
Spokane Valley, WA
I found Dave Frieburger's hotrod magazine 383 intake manifold shootout. Thank you Dave! If that guy weren't working for hotrod, that article would have never been in print. The engine was a mildly built 383. The Offy 360 dual quad intake didn't blow wind up anyone's skirt but didn't do poorly either. The interesting thing was that while the Eddy RPM did about the best overall on that engine, some of the low profile single planes numbers were just as good. We're talking Eddy Torker, Holley Street Dominator, Mopar M1 and even the old Eddy T6 Tarantula. Only difference being the RPM does better down low and the single planes had it up high. Given what I want to build, I think the performance of the would fall off a bit compared to the others.
I’m listening.
[Re: Big Bad Bee]
#879023
01/20/11 11:48 PM
01/20/11 11:48 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
The Offy manifolds were really misrepresented in that shootout, they had no jets/metering rods to properly calibrate the carbs. The offy tests were in the 10.9:1 a/f ratio range
[Re: Skeptic]
#879024
01/22/11 09:16 PM
01/22/11 09:16 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
Offy manifolds are definitely UNDERATED! They do make good power in multiples, but todays technology kinda tossed undeserving eggs in their faces. The best thing about these manifolds is the flow numbers - they stay close to when it was new. Meaning there is little fuel distribution problems within the manifolds. Some of their manifolds DO need modifications, maybe cause of engine (combination of parts mismatch) design or application ie: street/strip, cruising, all out bracket.
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
