Correct fuel pump for a 71 440-6 cuda. #878922
12/13/10 12:40 PM
12/13/10 12:40 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
WHats the correct fuel pumo for a 71 440-6 cuda?
And also, if the original is expensive or hard to find, is there something that can be bough off the shelf that looks like the original and that will supply enough gas volume for the 440.6 setup? Maybe something like those carter street pumps that supply around 120 gph at low pressure so no pressure regulator is required....any ideas?
Domingo
Re: Correct fuel pump for a 71 440-6 cuda. [Re: domingo] #878923
12/13/10 01:00 PM
12/13/10 01:00 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Re: Correct fuel pump for a 71 440-6 cuda. [Re: domingo] #878924
12/13/10 01:48 PM
12/13/10 01:48 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Domingo
That carter street pump looks like the HEMI pump so that won't cut it for you .
Re: Correct fuel pump for a 71 440-6 cuda. [Re: JohnRR] #878925
12/13/10 02:02 PM
12/13/10 02:02 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
This is the M4845
