Is a .050" quench height still effective? #878836
12/13/10 10:58 AM
12/13/10 10:58 AM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Looking into how I can tweak (lower) the CR a tad and one option is to run a .050" head gasket vs. the standard .040". If I open up the quench to .050", is it still going to be effective?
Re: Is a .050" quench height still effective? [Re: BradH] #878837
12/13/10 11:05 AM
12/13/10 11:05 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Re: Is a .050" quench height still effective? [Re: JohnRR] #878838
12/13/10 11:25 AM
12/13/10 11:25 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Better be, can't run any less with aluminum rods.
Re: Is a .050" quench height still effective? [Re: supercomp] #878839
12/13/10 12:10 PM
12/13/10 12:10 PM
BradH Offline OP
BradH  Offline OP
FWIW, mine is a steel-rod application.
Re: Is a .050" quench height still effective? [Re: BradH] #878840
12/13/10 12:18 PM
12/13/10 12:18 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
How much difference is a .010 thicker gasket going to make in CR??? The tighter the quench the cooler the charge, If your having detonation/pinging you might be better off backing off the timing a couple degrees.
Re: Is a .050" quench height still effective? [Re: ademon] #878841
12/13/10 12:31 PM
12/13/10 12:31 PM
BradH Offline OP
BradH  Offline OP
Between using a thicker gasket and choosing a gasket w/a larger ID (e.g. 4.45 or 4.50 vs. 4.38), I can "adjust" the CR down about .2 (from 11.0 to 10.8).
The concern is the cranking pressure w/ 11.0 and the cam on hand could be pushing it w/ the available pump gas octane (93), so I'm considering ways to address this w/o actually taking a step backward.
Re: Is a .050" quench height still effective? [Re: BradH] #878842
12/13/10 12:52 PM
12/13/10 12:52 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I'm running about 205 cranking psi on 93, But i run ram air, no heat crossover, very cold plugs, hi stall in lighter car and keep total timing at 30.
Re: Is a .050" quench height still effective? [Re: BradH] #878843
12/13/10 12:55 PM
12/13/10 12:55 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I would rather have the tighter quench with 11.00 to one than the .050 with 10.8 to one. I ran a 10.8 to one cast iron head with .038 with a .223 at 50 cam for years on 92 pump gas. Only time I had any problem was when the temp got in the high 90's. You would hear just a little in high gear. Couple gallons of race gas would fix it. With aluminum heads better combustion chamber shape and more cam duration I would think you would be OK.
Getting old just means you were smarter than some and luckier than others.
Re: Is a .050" quench height still effective? [Re: dannysbee] #878844
12/13/10 01:26 PM
12/13/10 01:26 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
My 440 is 11:1 and I run 91 octane. The cylinder pressure is 170 PSI, the pistons are .005 out of the hole with a .039 gasket.
Also the tops of my pistons are thermo coated as are the cumbustion chambers, valves, intake and exhaust ports and the inside and out side of the intake manifold.
Re: Is a .050" quench height still effective? [Re: BradH] #878845
12/13/10 01:31 PM
12/13/10 01:31 PM
NC
440Jim Offline
440Jim  Offline
NC
I don't have any data, but my feeling is that what you reduce the octane requirement by with the lower the CR, you will gain back with "less" quench. I don't think the quench is on/off, but more gradual change to the engine's octane requirement. So I wouldn't do that change in an attempt to need less octane fuel.
Re: Is a .050" quench height still effective? [Re: BradH] #878846
12/13/10 01:45 PM
12/13/10 01:45 PM
organ
maximum entropy Offline
organ
i know how much you value my input ( ), so i urge you to keep that quench as tight as possible! i've built several hot street engines with compression ratios close to 11:1, with very good results, as long as the quench is super tight. they've all been between .035 and .039. my personal mill started at .055, and had some issues in hot weather, that were completely ameliorated when i brought it to zero deck. i am the quench nazi because of this experience.
Re: Is a .050" quench height still effective? [Re: maximum entropy] #878847
12/13/10 02:09 PM
12/13/10 02:09 PM
sweden
sshemi Offline
sshemi  Offline
sweden
just use a bad battery and a slow starter when checking crank comp and the pressure will decrease.
Problem solved.
Re: Is a .050" quench height still effective? [Re: sshemi] #878848
12/13/10 02:13 PM
12/13/10 02:13 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I raced on 93 pumpgas with more quench than that at 11 to 1
Mopar Performance
Re: Is a .050" quench height still effective? [Re: maximum entropy] #878849
12/13/10 02:41 PM
12/13/10 02:41 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Was that the only change you did???
Re: Is a .050" quench height still effective? [Re: sshemi] #878850
12/13/10 02:46 PM
12/13/10 02:46 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
As others have stated tighter is better, your better choice is probably to use a thinner gasket, raise the compression but tighten the quench down to the low .03 range...
Re: Is a .050" quench height still effective? [Re: 1_WILD_RT] #878851
12/13/10 03:00 PM
12/13/10 03:00 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I shoot for and have seen the best results at a target of .040, I've run as tight as .036" on a 12:1 combo; To my mind you alsos have to be mindful about piston rock and remember the rock at TDC effects the quench area oppositely on each bank of a V8. I would consider anything above ~.045" the same as "no quench" and this applies only to steel rod combos.
WIZE
In Car:
Re: Is a .050" quench height still effective? [Re: Streetwize] #878852
12/13/10 04:19 PM
12/13/10 04:19 PM
BradH Offline OP
BradH  Offline OP
I'm seeing a pattern here...
FWIW, the pistons stick out of the deck .002", so quench will be .038" w/ a typical composition gasket.
I haven't assembled the thing, yet. However, I've collected most of the parts already. I don't know if I'll have to band-aid the 11.0 CR w/ a longer duration cam or not at this point.
Re: Is a .050" quench height still effective? [Re: sshemi] #878853
12/13/10 04:40 PM
12/13/10 04:40 PM
organ
organ
i put in a slightly smaller cam, which would have made the problem worse. i hoped that the improved quench would help the situation (not that it was that bad), and to my surprise, the hot weather pinging has vanished. the car is faster, too btw. 1/2 a tenth.
Re: Is a .050" quench height still effective? [Re: BradH] #878854
12/13/10 06:24 PM
12/13/10 06:24 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I also was at 11.12 to 1 in my challenger and I raced on 93 pump gas with that also! with a puny 248/254 @ 50 roller with more than .050 quench.... however The cam was 69 Intake valve closing ABDC..... ever wonder why wallace wants to know this on his dynamic calc? the higher the number the more its bleeds of cylinder pressure...
Ive seen miller post about this a few times also! good luck man
http://www.wallaceracing.com/dynamic-cr.php
Mopar Performance
Re: Is a .050" quench height still effective? [Re: moparniac] #878855
12/13/10 08:16 PM
12/13/10 08:16 PM
UK
602heavy Offline
602heavy  Offline
UK
Does early intake valve closure have a direct bearing regards detonation? , maybe excessive overlap (ex bias) has more influence than we think.. , lots of variables to think about regards valve events.
