Re: MSD E-CURVE DIZZY - GOOD / BAD ??????????
[Re: rickstershemi]
#878688
12/13/10 10:04 AM
12/13/10 10:04 AM
Posts: 1,051 The Great White North
RAMM
Don't bother. Buy the MSD 6AL-2 they are really worth it. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: sshemi]
#878692
12/13/10 04:57 PM
12/13/10 04:57 PM
Posts: 576 Escondido, CA
kick_the_reverb
Escondido, CA
The programmable MSD 6AL-2 has more features, but be aware that it has no real vacuum advance capability, in case that's important (for street driving). Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto Finally - disc brakes on the front. In the plans - rear disc brakes, B&M 250 blower
[Re: kick_the_reverb]
#878693
12/13/10 06:00 PM
12/13/10 06:00 PM
RAMM
Sure it does-hook up a MAP sensor. J.Rob
[Re: JohnRR]
#878694
12/13/10 06:28 PM
12/13/10 06:28 PM
Posts: 31,107 Oregon
AndyF
Do they make it for a big block ?
Nope. I've asked a couple of times but they don't seem too interested in making a big block e-curve. I'd run one if they did make it. I like being able to change the advance curves with just a twist of a screwdriver. And not having an ignition box saves some weight off the nose of the car.
[Re: AndyF]
#878695
12/13/10 06:48 PM
12/13/10 06:48 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
I like the e-curve. It has 100 timing curves built in plus it has vacuum advance. It is a really nice combo for a street/strip engine.
I agree, but am getting 50/50 comments on good/bad....if I end up throwing a 6 to it, that kinda kills the cost for me...???
Please post up some real world results & history
Rickster
[Re: AndyF]
#878697
12/13/10 08:34 PM
12/13/10 08:34 PM
rickstershemi
I don't see any bad comments, just some people telling you to buy something else. I'm not even sure why people are giving you that input since it isn't what you asked about.
The e-curve is a distributor, not an ignition box. It is an electronic distributor so you can quickly change the advance curve. Instead of welding up the slots, or changing springs, you just change a dial. So if you want a fast curve, or a slower curve, or more total advance, you just turn the dial. I've found it to be very handy to be able to change the ignition curve with just a twist of the screwdriver.
Thanks Andy....I totally understand how it works and love the concept....hence the thread....yes you can run it stand-a-lone or add a box (6al) etc.....but through searching info have heard nightmates on missfiring, complete failure.....then again those that simply love it....was looking on real world experience from my Moparts Brothers on those that may have some miles on the system....???????
The old school way: box, dizzy & coil is a little more, but not that much.....???????
Rickster
[Re: rickstershemi]
#878698
12/13/10 09:29 PM
12/13/10 09:29 PM
Posts: 22,790 Bitopia
jcc
Bitopia
I've had one for over 2 years, I like it, its clean, it works, its got VA, its flexible, It has all features needed, biggest negative is it takes a small screwdriver to adjust ( big deal), and I believe you can add a box later for additional ommph if needed. I'm suprised it hasn't caught on, maybe because I liked it. And its only a few miles from Lehigh
[Re: jcc]
#878699
12/13/10 10:29 PM
12/13/10 10:29 PM
rickstershemi
WHERE....???????
Yeah I've heard the dials are a tad on the fragile side and really should use a jewlers srewdriver to adjust (no problem)
Rickster
[Re: MR_P_BODY]
#878701
12/14/10 12:12 AM
12/14/10 12:12 AM
rickstershemi
Rickster
I've never used one but it sounds like more stuff to go wrong... I'm still the old school... K.I.S.S... JMO
I like the tuning ability....but you might be right
Rickster
[Re: rickstershemi]
#878702
12/14/10 12:20 AM
12/14/10 12:20 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Rickster
Rickster
Let me ask...how many times do you expect to change the timing curve... one I have it set its that way for good with that engine set up... the only thing with me is I dont need any extra hassles out on the road... its a half a step above my boat... I dont like fixing things on the water... which most of the time you dont have the part.... I dont like fixing things on the side of the road
[Re: rickstershemi]
#878703
12/14/10 02:44 AM
12/14/10 02:44 AM
AndyF
We run one on Tim's road race Valiant. Works great and makes good power on the dyno. We tossed the MSD 6 box because it was just extra weight that wasn't adding any power. Being able to quickly adjust the timing curves is a big advantage for tuning. I suppose once the perfect curve was found, a person could duplicate it in an old school mechanical distributor for the sake of simplicity. We haven't seen any issues with the e-curve so far on the dyno or at the track.
[Re: MR_P_BODY]
#878704
12/14/10 09:16 AM
12/14/10 09:16 AM
rickstershemi
Rickster
Rickster
I hear ya.....but looks like I'll have to be a guinea pig....the e-curve with coil is quite a bit less than the billet dizzy, 6AL & Coil pkg. Pulling the trigger on a bunch of stuff today to take advantage of the summit code & my pro-discount....should save a chit-load of $$$$$
Rickster
[Re: MR_P_BODY]
#878706
12/31/10 12:04 PM
12/31/10 12:04 PM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I have been looking at the E-Curve for my 408 also. Too bad there does not seem to be a lot of actual hands on experience with this unit. I am hoping that Firecore comes out with their Small Block Dist soon, I would much rather give that one a shot given the good reviews on the big blocks.
Let me us how it works out for you. Scott
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
[Re: finadk]
#878707
12/31/10 03:41 PM
12/31/10 03:41 PM
rickstershemi
Will do.....got it installed, nice piece (if it works) cars hitting the body/paint shop here in the next few weeks so in a couple of months it should be on the road
Rickster
