0 deck, any power to be had? #878658
12/12/10 11:32 PM
12/12/10 11:32 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
i understand 0 deck gives good quench and more compression,but would their be any power loss just by having piston in the hole vs 0 deck with same compression and quench?
Re: 0 deck, any power to be had? [Re: mopar dave] #878659
12/12/10 11:48 PM
12/12/10 11:48 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Sure if you have unburnt fuel due to bad combustion you stand to have predetonation on the next firing cycle. This is a negative force trying to push piston down when momentum is moving the piston up.
This is one of the areas of attack I am doing on a stock build. Not looking for power but wanting fuel economy. Power will just be a bonus.
Leon
Re: 0 deck, any power to be had? [Re: mopar dave] #878660
12/12/10 11:51 PM
12/12/10 11:51 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
ZERO deck with what type of head ? .... closed or OPEN chamber ??
Re: 0 deck, any power to be had? [Re: dOc …] #878661
12/13/10 12:00 AM
12/13/10 12:00 AM
Mt Morris Michigan
Mt Morris Michigan
closed. just curious of any power loss with piston in the hole. thanks
Re: 0 deck, any power to be had? [Re: dOc …] #878662
12/13/10 12:05 AM
12/13/10 12:05 AM
IN
ahy Offline
ahy  Offline
IN
I believe the main benefit of "zero deck" is to help achieve effective quench meaning about .040" clearnace between a good sized area of the piston and head - this with a closed chamber head. A similar result could be achieved with a FT piston below deck and a thin head gasket or with a piston below deck with quench dome.
Its just easiest - $ and hours of labor - to do well with a zero deck piston, closed chamber head and .040 head gasket.
Re: 0 deck, any power to be had? [Re: ahy] #878663
12/13/10 02:07 AM
12/13/10 02:07 AM
organ
maximum entropy Offline
organ
it is definitely worth it. at the very least, the engine will be less prone to detonation. at best, the engine will be less prone to detonation AND you'll go faster. this assuming that your compression ratio and cam are compatible.
Re: 0 deck, any power to be had? [Re: ahy] #878664
12/13/10 03:07 AM
12/13/10 03:07 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
It does make quench the easiest to obtain with most standard gaskets that fall around the .040 range. A Piston .020 in the hole with a .020 gasket will net the same result.
Also with Zero deck you may not need any Dome to acheive your "desired" compression. Flat tops have a slight advantage over domed pistons because of the easier/faster flame travel. IMO mike
Re: 0 deck, any power to be had? [Re: Leon441] #878665
12/13/10 09:59 AM
12/13/10 09:59 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Leon
Backing Leon up, eliminate the valve pockets too if you don't need them.
8.30's @3400 lbs
Re: 0 deck, any power to be had? [Re: Mike Swann] #878666
12/14/10 12:17 AM
12/14/10 12:17 AM
Mt Morris Michigan
Mt Morris Michigan
thanks for the opinions guys. now i know.
Re: 0 deck, any power to be had? [Re: mopar dave] #878667
12/14/10 12:39 AM
12/14/10 12:39 AM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
does anyone know of any tests done to test this theory? just curious because the shape of .020 of bore could affect the flame front differently from seeing that .020 in a head gasket correct? not saying would, just saying could. be an interesting test to see none the less
Re: 0 deck, any power to be had? [Re: Baxter61] #878668
12/15/10 12:03 AM
12/15/10 12:03 AM
IN
ahy Offline
ahy  Offline
IN
I haven't seen any test results but I'd confidently predict that on a typical street/strip engine at around 1 HP/cu in the difference would be too small to measure.
On a more extreme combo like a "super stock" Hemi at 2 HP/cu in, or NACSAR, or F1 it could make a noticible or critical difference.
Re: 0 deck, any power to be had? [Re: ahy] #878669
12/15/10 01:22 AM
12/15/10 01:22 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
If your set on running on the ragged edge of the fuel you'll buy go for tight quench. I'll buy better fuel and quit the BS. Power adder combo's,I'd skip quench and not look back.
Re: 0 deck, any power to be had? [Re: Baxter61] #878670
12/15/10 04:54 AM
12/15/10 04:54 AM
California, USA
Tiger Core Offline
Tiger Core  Offline
California, USA
I've tested this but in a laboratory and not on a Mopar engine or in terms of drag times, unfortunately. It was during engine development for an Jaguar engine. Burn duration is measured in 10-90% burn time. What was found was that when the squish was maintained at 0.9 to 1mm (35 thou to 39 thou) there was a measurable improvement in burn duration of a couple of degrees. This manifested itself as less ignition advance required when optimised for best torque. Once squish clearance increased to 1.2 to 1.3 mm (47 to 51 thou) you ended up with a flame front quench zone which was detrimental to combustion (forming a rich pocket) and in some cases was a source of detonation. Effective squish not only depends on the clearance but also the stroke length/mean piston speed. This means that squish is more effective on longer stroke engines, such as the older Jaguar AJ16 and less effective on the shorter stroke motors such as the Jaguar AJ26 V8. I would venture to say that it becomes more effective once a stroke length of greater than about 90mm is used. In our case our RBs have a healthy stroke of about 95mm as standard
Re: 0 deck, any power to be had? [Re: Tiger Core] #878671
12/15/10 05:18 AM
12/15/10 05:18 AM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
I wasnt referring to the squish itself but as to were its found. Such as a piston being .020 down in the bore and using a .019 head gasket vs. 0 deck piston and .039 head gasket, all else being equal.
Re: 0 deck, any power to be had? [Re: Baxter61] #878672
12/15/10 05:21 AM
12/15/10 05:21 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've heard of guys doing it both ways and I really don't think you're going to see any measurable difference.
Re: 0 deck, any power to be had? [Re: DaytonaTurbo] #878673
12/15/10 05:36 AM
12/15/10 05:36 AM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
my thoughts also are that theres not much different, just curious if anyone has tested it to find out.
Re: 0 deck, any power to be had? [Re: DaytonaTurbo] #878674
12/15/10 05:38 AM
12/15/10 05:38 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
On the flip side I recall Jon Kaase running a thick head gasket with the piston crown out of the bore. Some of the engine master contestants have running some pretty tight quench in the past (around 0.030")
Alan Jones
Re: 0 deck, any power to be had? [Re: LA360] #878675
12/15/10 11:27 AM
12/15/10 11:27 AM
Mt Morris Michigan
Mt Morris Michigan
yeah, is there any harm or power loss with the piston above the deck?
Re: 0 deck, any power to be had? [Re: mopar dave] #878676
12/15/10 12:44 PM
12/15/10 12:44 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
I Would venture that if the piston comes out of the bore the easier it would be to burn the top ring
and also would be hard to run 36 to 38 deg total timing .
The thicker the top ring land with cooling groves helps prevent detonation.
1969 Dodge Charger 1969 Dodge Superbee
Re: 0 deck, any power to be had? [Re: cjs69mope] #878677
12/15/10 09:38 PM
12/15/10 09:38 PM
California, USA
Tiger Core Offline
Tiger Core  Offline
California, USA
The 1996 to 1998 Porsche 911 (993) Turbo piston protrudes 5mm above the deck BY DESIGN at TDC.
This engine makes about 450 Bhp and 420 lb ft of torque from a 3.6 litre capacity. The Chamber design isn't disimilar to a Gen 2 Hemi (with some refinements).
This is done in order to reduce peak cylinder pressure load on the cylinder head gasket just after TDC.
