JW bell?? Trans Shield??? Trans Blanket?? #876803
12/10/10 03:00 PM
12/10/10 03:00 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
What does everyone use? What do you like what don't you like...
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: JW bell?? Trans Shield??? Trans Blanket?? [Re: DemonDust] #876804
12/10/10 03:07 PM
12/10/10 03:07 PM
CT
turbocolt2.4L Offline
CT
i run the csr carbon shield hugs the 904 nice i have a very tight fit in mt colt
Re: JW bell?? Trans Shield??? Trans Blanket?? [Re: DemonDust] #876805
12/10/10 03:08 PM
12/10/10 03:08 PM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
If you're referring to a P/G application I used a J/W bell adapted from the glide to my BB and a Reactor brand flywheel that adapted from the crank to a 'glide convertor, worked great, no problems...except now that I don't use a 'glide anymore I have a shelf full of glide convertors and a 'glide (no bell or flywheel, sold it with the dragster)that I can't seem to sell...
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: JW bell?? Trans Shield??? Trans Blanket?? [Re: RapidusMaximus] #876806
12/10/10 03:19 PM
12/10/10 03:19 PM
Menomonee Falls
Menomonee Falls
I guess I should have said Im using a 904...
SDG Motorsports
Re: JW bell?? Trans Shield??? Trans Blanket?? [Re: RapidusMaximus] #876807
12/10/10 03:22 PM
12/10/10 03:22 PM
Menomonee Falls
Menomonee Falls
Should have known sooner, I may have been interested in it for the right price before I decided to go with the 904....
SDG Motorsports
Re: JW bell?? Trans Shield??? Trans Blanket?? [Re: DemonDust] #876808
12/10/10 09:25 PM
12/10/10 09:25 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
On my 904 I use a CSR its awsome but its also in a tube chassis with a removable tranny hump in the floor. On my Dart w/727 I'm going to use a Ultrabell. Just no room to get a CSR in there without beating the body all to heck.
Re: JW bell?? Trans Shield??? Trans Blanket?? [Re: 80arrow] #876809
12/11/10 12:50 AM
12/11/10 12:50 AM
Menomonee Falls
Menomonee Falls
I have a removable trans tunnel from my 833 with the Vgate and lakewood bell. I could probably get away with just a shield instead of a JW bell. Cause lets face it, either way if something catastrophic happens the trans is junk and your feet are safe...
SDG Motorsports
Re: JW bell?? Trans Shield??? Trans Blanket?? [Re: DemonDust] #876810
12/11/10 11:27 AM
12/11/10 11:27 AM
8
80arrow Offline
80arrow  Offline
If you have a removable trans tunnel I'd use the CSR shield, since you can get to the bellhousing bolts easily and line everything up from inside the car. You'll have to cut 1 or 2 pieces off the 904 bell on top but for the most part I really like mine. The Ultrabell is a little more involved. And yes either of them is a very good idea.
Re: JW bell?? Trans Shield??? Trans Blanket?? [Re: DemonDust] #876811
12/11/10 12:11 PM
12/11/10 12:11 PM
SW Missouri
W
willp Offline
willp  Offline
W
SW Missouri
Be sure and check to see if you will need to put the larger starter ring on your convertor. If I remember correctly when using a 904 you have to go to a 140(?) tooth starter ring gear. I would call JW.
