Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: charger'72mod] #876228
12/11/10 04:55 PM
12/11/10 04:55 PM
Sonora. Mexico
charger'72mod Online content
charger'72mod  Online Content
Sonora. Mexico
another picture
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: charger'72mod] #876229
12/11/10 04:58 PM
12/11/10 04:58 PM
Sonora. Mexico
Sonora. Mexico
last one
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: charger'72mod] #876230
12/11/10 06:04 PM
12/11/10 06:04 PM
Boise Idaho
Boise Chall Offline OP
Boise Idaho
Is that a -B- on the front of the passenger mount what does that mean?? I just noticed Mine has an -A- on it is this a way to tell the difference between the big block and small block K-frames? I'm getting totally confused here why do factory big block mounts in a factory small block K-frame work for some people but others it won't. My engine compartment and K-frame will be painted before I load the motor in from the top. I wasn't planning on doing a test fit before painting but now I'm thinking I better.
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: Boise Chall] #876231
12/11/10 06:26 PM
12/11/10 06:26 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
My first engine swap ever was dropping a 383 six pack into a 73 RR that was a 318 car. Took all summer because (as a kid) I thought it would just bolt in.
After some research, I bought (IIRC) 400 Motor Mounts for 73 RR and I had to change the oil pan because the 383 sump hit the K-member and would keep the back of the engine from dropping down correctly. I went to a JY that had HUGE STACKS of OIl Pans. I spent several hours going through the oil pans until I found the one that would had the sump further back than mine. Don't know what it came from it was in the stack. Once I put the oil pan on, everything lined up fine. I do not know what the 383 engine and trans originally came out of but I pulled them from a 66 Fury a guy had "rodded". I don't recall having any issues getting the transmission to work, however the tail shaft was longer on the big block trans and I had to get a shorter driveshaft which I found in a wrecked big block RR in a local JY at the time.
Car ran and drove great w/ no issues.
65 Barracuda
70 Challenger
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: jrwoodjoe] #876232
12/12/10 02:41 AM
12/12/10 02:41 AM
St Louis, Missouri
Runnin74 Offline
Runnin74  Offline
St Louis, Missouri
Looks to me like the big block and small block k-frames are different. The small block mounts are set further forward and the left one is slightly more forward than the right mount.
See the photo - compares the above big block k-frame pics to pics of my small block k-frame.
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: Runnin74] #876233
12/12/10 03:46 AM
12/12/10 03:46 AM
Boise Idaho
Boise Idaho
Thank you for the comparison pics I will order the Schumacher mounts on Monday. Schumacher's website says you need to cut some of the mount for oil pump clearance. Has anybody done this ? can it be done safely after the K-frame/engine compartment are painted ?
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: Runnin74] #876234
12/12/10 03:51 AM
12/12/10 03:51 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The k-frames are physically the same pieces, the difference is where the motor mount perches are welded onto the k-frame. My car came with the 440 in the small block k-frame with original type 440 mounts. It fit in but I have since changed to the schumacher conversion mounts. When I first got the car, the 440 sat too high in the front and too far forward. The conversion mount dropped the motor down about 1" and moved it back about 1". I now have more fan-rad clearance and it got rid of a pinion angle mis-match which was causing a vibration at speed. It fit with the mis-matched stock stuff but I now have more clearance for aftermarket intakes/air cleaner and my el-cheapo summit headers fit great.
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: DaytonaTurbo] #876235
12/12/10 02:28 PM
12/12/10 02:28 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
....And the whole trouble and confusion begins with the fact that the big block WILL just sit right in there tricking someone into thinking it's a done deal...They should have spread the mounts from BB to SB to avoid the confusion...
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: Runnin74] #876236
12/12/10 05:34 PM
12/12/10 05:34 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Great pics showing EXACTLY what I said as far as them being straight VS staggered.....You can physically set the motor in but nothing lines up you can see how crooked it would be as my tailshaft was pointing towards the rear shock....Manifolds make it look like it could fit but put headers and a trans behind it and you'll see how incorrect it is. I will check on my car how much I trimmed but I don't think trhe pics showed have enough clearance on the top part....Too cold and wet to look out in the garage today....
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: QuickBpBp] #876237
12/12/10 06:06 PM
12/12/10 06:06 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Wish I had been able to access info. like this when I did my car. Maybe, it wouldn't have took all summer. I know that I was able to get it to work but perhaps the alignment was off w/o me knowing. I do not recall anything being terribly out of line but there is obviously a difference between the 2 K-members as shown in the pics.
Joe
65 Barracuda
70 Challenger
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: jrwoodjoe] #876238
12/12/10 10:32 PM
12/12/10 10:32 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
Thanks Guys
Now I know for sure it is a BB K-member like my dad said, but I have no idea what mounts to use or how they go on the engine. ANy help would be appreciated.
Seems that the last three cars I owned have used motor plates.
Re: 73 Satellite / Roadrunner BB or small block K-frame [Re: RonP] #876239
12/13/10 01:49 AM
12/13/10 01:49 AM
Manitoba, Canada
Manitoba, Canada
It's pretty straight-forward. You need a set of spool type BB motor mounts. The mounts bolt to the ears on the block and each mount takes one long bolt that bolts the mount to the k-frame perches. Should be able to score what you need for pretty cheap.
