340 Motor Mounts. #876027
12/09/10 08:33 PM
12/09/10 08:33 PM
Hamburg, Pa.
72 RR DUDE Offline OP
Hamburg, Pa.
Are 340 motor mounts brackets the same as 318 brackets.Looking for a set for a 72 B-body with a 340 and some say they are the same and some say a are different.Anybody know?
Re: 340 Motor Mounts. [Re: 72 RR DUDE] #876028
12/09/10 08:37 PM
12/09/10 08:37 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
The distance between mounting flanges on the driverside of a 340 are 1/2 narrower than the 318. Here is a photo of the measurement on a 340. Approx. 2 1/2" 318 is approx. 3" measured the same way.
Joe
65 Barracuda
70 Challenger
Re: 340 Motor Mounts. [Re: jrwoodjoe] #876029
12/09/10 08:48 PM
12/09/10 08:48 PM
Hamburg, Pa.
Hamburg, Pa.
Any pictures anyone?
Re: 340 Motor Mounts. [Re: 72 RR DUDE] #876030
12/09/10 08:48 PM
12/09/10 08:48 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Just posted one above.
Re: 340 Motor Mounts. [Re: jrwoodjoe] #876031
12/09/10 08:55 PM
12/09/10 08:55 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
These are A body style mounts one of which was converted. It will give an idea of the distance change.
Re: 340 Motor Mounts. [Re: RobX4406] #876032
12/09/10 09:05 PM
12/09/10 09:05 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
360 mounts are also the same as 340 if you fine some of those.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 340 Motor Mounts. [Re: moparmarks] #876033
12/09/10 10:26 PM
12/09/10 10:26 PM
RobX4406 Offline
RobX4406  Offline
This is a set of 340/360 mounts for B bodies
A member here had these on a Dart and is looking for a set of A body mounts. If you have a set of A's I bet he'd trade you.
Re: 340 Motor Mounts. [Re: RobX4406] #876034
12/10/10 02:43 PM
12/10/10 02:43 PM
WILKES-BARRE PA
Joesixpack Offline
Joesixpack  Offline
WILKES-BARRE PA
B/C/E body 318 mounts will work on any 340-360, the passenger side is a direct interchange...on the drivers side you can use the 318 mount on the 340-360 engine block, just bolt it to the ears of the block,you will see a small(1/8 to 1/4 gap)between the od of the ear on the block and the id of the steel bracket at 1 bolt hole, just fill in the gap with a stack of grade 8 washers or make a small spacer and tack it to the steel bracket.the quickest way to figure it out is to bolt the drivers side 318 steel bracket to the ears of the 340-360 engine block,2 holes and bolts will line right up and go in and tighten up putting the mount in its proper place....the third hole will line up also, just the above mentioned gap will be seen,fill it in and then tighten up all 3, your done. THIS WILL NOT WORK WITH A BODIES, JUST B,C,E .
Re: 340 Motor Mounts. [Re: Joesixpack] #876035
12/10/10 02:53 PM
12/10/10 02:53 PM
WILKES-BARRE PA
Joesixpack Offline
Joesixpack  Offline
WILKES-BARRE PA
Courtesy of Greg Purcell....
Re: 340 Motor Mounts. [Re: RobX4406] #876036
12/10/10 04:06 PM
12/10/10 04:06 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
These are early A body mounts but the later (72/73? up) use the spool mounts.
Make no difference that I have ever seen.
Re: 340 Motor Mounts. [Re: MoparforLife] #876037
12/10/10 06:06 PM
12/10/10 06:06 PM
WILKES-BARRE PA
Joesixpack Offline
Joesixpack  Offline
WILKES-BARRE PA
lol try taking A-body 273-318 drivers side bracket and bolt it on a 340-360 block, am talking 1967-1972,here is that bracket pictured , it does not even have the piece of steel where the bolt goes....you would have to weld an ear and drill it out to get it to work, passenger side is ok, they interchange. look at the picture provided by the member who modified 1 to work.
