Re: 71-74 Satellite/Runner folks Wheel size help quick!!!
[Re: RonP]
#875472
12/09/10 10:57 AM
12/09/10 10:57 AM
Posts: 1,978 Southaven, MS
BossRide
Southaven, MS
I'm running 15x8s and 15x10s. The fronts have a stock backspacing of 4.5" I think, and the rears have around 4.5" also. I probably should have went with 5" but I wanted more lip. I did have to gently roll the inner fender lip a bit to keep it from cutting the sidewall, but I cut nothing. For reference, here is the 15x8s mounted on the back: There is plenty of room in the wells.
The Blue Goose
My instagram: Bossride
[Re: BossRide]
#875473
12/09/10 10:58 AM
12/09/10 10:58 AM
BossRide
Southaven, MS
Oh yeah, yes on your 4.5 bolt pattern.
The Blue Goose
[Re: RonP]
#875474
12/09/10 11:01 AM
12/09/10 11:01 AM
Posts: 2,325 Löffingen, Germany
The_Mean_Machine
Löffingen, Germany
I run 8.5 x 15 with 3.5" BS (not 100% sure on the BS, but its the standard BS for this particular wheel). Tires are 245/60, all 4 corners the same. I had to massage the rear wheel well flange a bit on the passenger side because the tire dit not clear. If you want a wider tire, you need 4 to 4.5" BS Frank
