#1
You can probably figure out a way to lock yours down, as others have said.
#2
Or, Rock Auto has a listing on one for 77 NYB 440, has dual pickups and no vacuum advance. Cardone #303866, $50, no core charge. Other years with single pickup are listed as rebuild-return only, but this one is available. I bought 2 a while back just for future EFI use, parts like those ain't gonna be available forever.
#3
If you can find any LeanBurn dizzy, you can play mix-match with your parts. All the pre-TBI, V8, electronic ignition dizzy housings are the same height. The dizzy shafts differ in how far they protrude into the block. Visit the '5.9 EFI a different way' thread, I put a bunch of dizzy info in there. That's for a slightly different purpose, but I think the clues you need are in there near the end of the thread.
