Please identify these rocker arms... #874912
12/08/10 07:26 PM
12/08/10 07:26 PM
North Carolina
fastmopars Offline OP
North Carolina
I bought these a few yrs ago and not really sure what brand and what heads they fit. They are needle bearing type and have an offset intake.
Thinking the are Harland Sharpes and for a w-8 head??
Re: Please identify these rocker arms... [Re: fastmopars] #874913
12/08/10 07:27 PM
12/08/10 07:27 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Norris aluminums??
Dono, but look nice!!
Re: Please identify these rocker arms... [Re: fastmopars] #874914
12/08/10 07:30 PM
12/08/10 07:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What color are they
Re: Please identify these rocker arms... [Re: MR_P_BODY] #874915
12/08/10 07:32 PM
12/08/10 07:32 PM
North Carolina
North Carolina
They arnt gold like the cranes.. They really look like the harlands I have for on my big block.
Re: Please identify these rocker arms... [Re: fastmopars] #874916
12/08/10 07:33 PM
12/08/10 07:33 PM
looks like mine (H.S. BB) to
Re: Please identify these rocker arms... [Re: Cab_Burge] #874917
12/08/10 07:41 PM
12/08/10 07:41 PM
North Carolina
North Carolina
Im going to list these for sell but I want to make sure what they are and what they fit first...
Re: Please identify these rocker arms... [Re: fastmopars] #874918
12/08/10 07:47 PM
12/08/10 07:47 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
these are standard HS BB rockers and they look nothing like those
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Please identify these rocker arms... [Re: dusturbd340W5] #874919
12/08/10 07:49 PM
12/08/10 07:49 PM
Kissimmee Fl.
Kissimmee Fl.
I say they look more like a w2 w5 offset to me looks like the intake is offset and the exhaust is centered.
Re: Please identify these rocker arms... [Re: dusturbd340W5] #874920
12/08/10 07:51 PM
12/08/10 07:51 PM
North Carolina
North Carolina
The shafts are not big block for sure.
Thats why I thought they were for maybe for a w-8 head because of the offset intakes. They do have the needle bearings like the Harlands.
Re: Please identify these rocker arms... [Re: fastmopars] #874921
12/08/10 07:52 PM
12/08/10 07:52 PM
Kissimmee Fl.
Kissimmee Fl.
I don't think a w8 uses a single shaft like that but I could be wrong
Re: Please identify these rocker arms... [Re: dusturbd340W5] #874922
12/08/10 07:54 PM
12/08/10 07:54 PM
North Carolina
North Carolina
Im not sure how to measure offset.
Re: Please identify these rocker arms... [Re: dusturbd340W5] #874923
12/08/10 07:54 PM
12/08/10 07:54 PM
Kissimmee Fl.
Kissimmee Fl.
just looked a the w8 pictures in the tech they use a jesel type set up with individual shafts
Re: Please identify these rocker arms... [Re: dusturbd340W5] #874924
12/08/10 07:59 PM
12/08/10 07:59 PM
ohio
all spooled up Offline
ohio
how do you know there for mopars???????????
Re: Please identify these rocker arms... [Re: dusturbd340W5] #874925
12/08/10 08:03 PM
12/08/10 08:03 PM
North Carolina
North Carolina
Ok.. So I probably have rockers for a w2, w5 head?
Re: Please identify these rocker arms... [Re: fastmopars] #874926
12/08/10 08:14 PM
12/08/10 08:14 PM
ohio
ohio
not enuff offset for w2 w5s
Re: Please identify these rocker arms... [Re: fastmopars] #874927
12/08/10 08:14 PM
12/08/10 08:14 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
They don't have enough offset to be W2/5 & they are NOT W7/8/9 Those use individual paired rockers.
My best GUESS without seeing them in person, is OLD Harland Sharps for TA heads. But every Sharp I have ever seen in past 10-15 years were that dark bronze color they still use. Everything else about them suggests HS.
The offset looks like TA offset... Maybe B1-BA Brodix, they had some with a relocated pushrod hole like a TA/INDYBrock. They could have been custom made for set of B1 BA heads as well.
Re: Please identify these rocker arms... [Re: dusturbd340W5] #874928
12/08/10 08:18 PM
12/08/10 08:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No they dont look like W-8 stuff... I put a set of W-8
TDs on the for sale section yesterday and the W-8 is
the little short shafts(each cyl)
Re: Please identify these rocker arms... [Re: MR_P_BODY] #874929
12/08/10 08:37 PM
12/08/10 08:37 PM
North Carolina
North Carolina
I hadnt thought about the TA heads or the B1-BA Brodix. I thought they didnt have enough offset for w2s.
Re: Please identify these rocker arms... [Re: fastmopars] #874930
12/08/10 08:51 PM
12/08/10 08:51 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
After looking @ them some more I'd bet $ they were built for a TA or B1-BA. One or the other & I doubt they were made recently.
I assume the bolt holes in the shafts are in the center of the shaft & not offset?
Re: Please identify these rocker arms... [Re: fastmopars] #874931
12/08/10 09:18 PM
12/08/10 09:18 PM
organ
maximum entropy Offline
organ
harland has always machined the adjuster seat and threads after anodizing, yes? i don't think those are h.s.
