Brake linkage #874841
12/08/10 06:10 PM
12/08/10 06:10 PM
S.W. Ohio
clyde Offline OP
clyde  Offline OP
S.W. Ohio
Is the linkage between the pedal and the m/c same on front disc cars as front drum cars? E-body THX
Re: Brake linkage [Re: clyde] #874842
12/10/10 06:08 PM
12/10/10 06:08 PM
S.W. Ohio
clyde Offline OP
clyde  Offline OP
S.W. Ohio
Musta been a hard question
Re: Brake linkage [Re: clyde] #874843
12/10/10 07:05 PM
12/10/10 07:05 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
When I changed my 72 Challenger automatic from Manual to power brakes I changed everything including the bracket that the linkage goes to under the dash.
Re: Brake linkage [Re: clyde] #874844
12/10/10 07:05 PM
12/10/10 07:05 PM
scratchnfotraction Offline
Re: Brake linkage [Re: clyde] #874845
12/10/10 07:26 PM
12/10/10 07:26 PM
Central TX
roe Offline
roe  Offline
Central TX
i sold a buddy a '72 satellite with manual drums all around. Also gave him the complete power disc setup from another car, pedal linkage, booster, and complete setup from upper control ARM to lower control arm.
instead of converting to power he just put on the disc brake gear but kept his drum linkage, said it works great.
from everything I've ever come across you only have to change linkage if you go from manual to power. the manual linkage gives more leverage and can lead to overly touchy brakes if used with a power brake setup.
from everything that I've come across you only have to changethe linkage if you go from manual to power brakes. the manual linkage gives you more leverage and can lead to overly touchy brakes if used with a power setup.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Brake linkage [Re: clyde] #874846
12/10/10 08:14 PM
12/10/10 08:14 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
afaik,
No
