overdrive
#874733
12/08/10 03:24 PM
12/08/10 03:24 PM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
Just thinking about the possibility of using a 1989 truck version of a 700R4 behind my big block street machine. The trans was in my 1989 1/2 ton Suburban and gave no trouble at all pulling a 32' camper. I recently had the trans rebuilt (preventative maintenance) and then ended up junking the body because of rust issues. The trans is non-electronic. I see that TCI has an adapter for this swap. Part number 149260 is 1/4" thick for the 6 bolt crank. Has anybody done this swap? The trans seems no larger than the 727 in the car now. Looks like the linkage from the GM throttle body to the trans can be easily adapted to my carbs.
This is the land of the free
because of the brave
Re: overdrive
[Re: rbstroker]
#874734
12/08/10 07:33 PM
12/08/10 07:33 PM
Posts: 25,836 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The early versions of the 700R4 aren't very strong in stock form, if the internals were upgraded during the rebuild it should be OK behind a BB.
Re: overdrive
[Re: rbstroker]
#874735
12/09/10 10:55 AM
12/09/10 10:55 AM
rbstroker
West Tennessee
Thanks for the input, John. Are you aware of anyone doing the swap using the TCI adapter, and whatever issues they may have run into? Just looking at it, it looks like the starter location will be one issue. Speedometer cable hookup may be another. The cooling lines on the opposite side is easily overcome. Now that I am going to be strictly on the street, I sure would like to be able to run freeway speeds at lower RPM yet have plenty of "gear" for around town.
Re: overdrive
[Re: Dodgem]
#874737
12/09/10 04:16 PM
12/09/10 04:16 PM
rbstroker
West Tennessee
Gear Vendors is undoubtedly good, but if the 700R4 will make a decent setup for an early B body, I have the trans already. Not too concerned about strength as I had well over 100,000 miles on the original 700R4 before getting it rebuilt. Absolutely no problems. Besides, it is winter time, and I am looking for a "winter project". Sure would like to hear from anyone who tried this swap already.
Re: overdrive
[Re: rbstroker]
#874738
12/11/10 10:17 AM
12/11/10 10:17 AM
rbstroker
West Tennessee
Has anyone used the TCI 149260 or 149265 kit? Looks like the starter would be in the stock position. There is a Wilcap adapter available, but it moves the starter and requires the use of a mini-starter also. My 700r4 (non-electronic) is freshly rebuilt and originally gave me 100,000 trouble free miles in my 1989 suburban. The car I want to put it in is an early (1965) B body. The engine/trans in the early B's sits a couple of inches further forward than the '66 and later, possibly giving even more room for the trans. I have the 700r4 sitting next to a spare 1965 727, and it looks like the 700 may actually be narrower and is definitely shorter. The mount actually seems to be no more than 1/2" difference. No cutting on an original body and the ability to return to stock, is an appealing fringe benefit. I need to get all the info that I can before I even think about taking my freshly painted car apart. I know some cringe at using a GM trans in a Mopar, but isn't that what hot rodding is about, using what you have available? Thanks,
