Is this Tic Toc Dash NOS? #874691
12/08/10 01:33 PM
12/08/10 01:33 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
I have a dash and am not sure if it is NOS. Is is worn in a few places but the odometer reads all 0s and there are signs that it was never installed in a vehicle. I had a much more experienced collector tell me he thought it was NOs with shelf wear. Any comments are helpful
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor 1969 Dodge Coronet 500 1956 Desoto Hemi 1955 Chrysler C300
Re: Is this Tic Toc Dash NOS? [Re: 68 Sat] #874692
12/08/10 01:34 PM
12/08/10 01:34 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
2nd pic
Re: Is this Tic Toc Dash NOS? [Re: 68 Sat] #874693
12/08/10 01:49 PM
12/08/10 01:49 PM
MD
Moparlang Offline
Moparlang  Offline
MD
These dashes were assembled with individual components, the speedo could be, but most over the counter replacement speedo's had red tenths numbers. The circuit board appears to be missing a couple pins, also.
The "mailman's son" Bad mailman!!
Re: Is this Tic Toc Dash NOS? [Re: Moparlang] #874694
12/08/10 01:59 PM
12/08/10 01:59 PM
waukon iowa
1hot68 Offline
1hot68  Offline
waukon iowa
It doesnt have a tic toc tac....That much I can tell ya.
Re: Is this Tic Toc Dash NOS? [Re: 1hot68] #874695
12/08/10 02:09 PM
12/08/10 02:09 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
"the pin" on the outside is the second hand
looks like production assembled unit Dec. '68 date on housing & Apr. '69 date on clock ...... it might have been replaced under warranty (due to issues it still has?), odometer rolled, and set on a shelf in a dealer's parts room
Re: Is this Tic Toc Dash NOS? [Re: 1hot68] #874696
12/08/10 02:09 PM
12/08/10 02:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If it's NOS it was constructed of NOS parts and it has a ton of shelf wear , you could not go to the dealer and order it like that.
Re: Is this Tic Toc Dash NOS? [Re: JohnRR] #874697
12/08/10 02:13 PM
12/08/10 02:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
B Body rallye instrument cluster (1969 Dodge - reflective knob control surrounds) with 0 miles on the odometer. I have had this inspected by a professional and it appears to not have been tampered with. It is complete with the exception of the alternator gauge and there are two pins that are broken in the rear. Although I can not call this NOS it is close. If you are looking to restore your B Body this is a great addition to your car. I do not know if the cluster works properly but ask me any questions that help you make your desision. This item also fits Road Runner, GTX, Coronet, Super Bee, dashboards but I believe only 1968-70 models. Please correct me if I am wrong....
You're wrong . 68 , 69 and 70 each had it's own dash face and 70 was different because the Hazard switch was moved off the dash and onto the column . This is either 69 or 70 , can't tell off the top of my head , if it's 69 it's superbee , charger and optional on coronet only , and as said it doesn't have a tac , but you did well SPAMMING with all your buzzwords ...
Re: Is this Tic Toc Dash NOS? [Re: JohnRR] #874698
12/08/10 02:17 PM
12/08/10 02:17 PM
waukon iowa
1hot68 Offline
1hot68  Offline
waukon iowa
Its a 69 one because it has the pebble grain with the flasher switch. 70 is same minus the flasher switch.
Re: Is this Tic Toc Dash NOS? [Re: JohnRR] #874699
12/08/10 02:19 PM
12/08/10 02:19 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
OK,
Thats why I asked... I'll modify my post and go from there.. thanks...
Re: Is this Tic Toc Dash NOS? [Re: 68 Sat] #874700
12/08/10 02:29 PM
12/08/10 02:29 PM
waukon iowa
1hot68 Offline
1hot68  Offline
waukon iowa
What you have is just a clock. The part thats fooling you around thee outer part is the seconds on the clock.
Re: Is this Tic Toc Dash NOS? [Re: 1hot68] #874701
12/08/10 02:38 PM
12/08/10 02:38 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
Yeah,
I figured it out..I am glad I asked. Thanks again...Do you believe this is a true 0 miles odometer?
-C
Re: Is this Tic Toc Dash NOS? [Re: 1hot68] #874702
12/08/10 02:49 PM
12/08/10 02:49 PM
Vicksburg, MI
coffeeman383 Offline
Vicksburg, MI
I always wondered why my old RR rev'd so slowly!
Re: Is this Tic Toc Dash NOS? [Re: 68 Sat] #874703
12/08/10 06:12 PM
12/08/10 06:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yeah,
-C
It really doesn't matter if it is , it's very easy to turn it back to zero.
Re: Is this Tic Toc Dash NOS? [Re: 68 Sat] #874704
12/08/10 07:28 PM
12/08/10 07:28 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Yeah,
-C
I don't. Look how the speedo numbers on the right are more yellow than the ones on the left. This is typical of the fading that you get with the cluster installed in the car.
In my opinion, it's a used part with a rolled back speedo.
Re: Is this Tic Toc Dash NOS? [Re: Morty426] #874705
12/11/10 06:32 PM
12/11/10 06:32 PM
Texas, Dallas
G_T Offline
G_T  Offline
Texas, Dallas
ive not seen a new/nos speedometer with all 0's.... i would think it would have a couple of tenths of a mile on it from testing/calibration... just guessing...
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com 2012 Charger SRT8
