69 Charger FRAME AND BODY STRAIGHT ?????? #874518
12/08/10 09:42 AM
12/08/10 09:42 AM
North Carolina
rg69charger Offline OP
North Carolina
Can anyone help with good info on making sure your body and frame are level and straight while working on pans and fenders, weather its backyard or engineer methoreds. Just trying to keep her perfect as possible. Thanks for all the help in the past too! MOPAR people are the BEST
Re: 69 Charger FRAME AND BODY STRAIGHT ?????? [Re: rg69charger] #874519
12/08/10 10:12 AM
12/08/10 10:12 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The method I've used for at home is using a 4ft lever from side to side shimming the rails as needed to level the car side to side, then using a factory frame chart I use 8 jack stands 2 per frame rail so I can set the heights, Finally I measure all the dimensions shown on the frame chart.. I'm attaching a 69 Coronet chart, I suspect it would work for your Charger but a factory shop manual would have the correct one....
