Transmission troubles? #87434
07/12/08 10:38 AM
07/12/08 10:38 AM
IL
71dusta Offline OP
71dusta  Offline OP
IL
I just put my newly rebuilt 904 back in my car and it worked great for a couple short drives and then it stopped shifting into 3rd gear in drive or manually. I have tried to adjust the kickdown but hasn't changed anything yet. If someone has had this problem before or any advice I would appreciate some help. All I can think is something is messed up in the valve body but not sure what. Thanks for any help
Automotive and Kustom Art www.nategrice.blogspot.com
Re: Transmission troubles? [Re: 71dusta] #87435
07/12/08 07:55 PM
07/12/08 07:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Does Reverse work OK?
Re: Transmission troubles? [Re: 71dusta] #87436
07/13/08 02:35 AM
07/13/08 02:35 AM
N
neonroadrunner Offline
N
About 6 years ago I had the exact same issue with a newly rebuilt 727. A few days of driving I lost 3rd gear. I talked to the guy who rebuilt it, he was nice enough to come out to my house and drop the trans pan.He seemed to know exactly what the issue was.A snap ring had popped out for an accumulator piston that was for applying a band to hold somthing or other,basicaly so it would shift into third.Nothing was damaged he just popped everything back together and it has been shifting fine. He told me this was common on a rebuild that the new snap ring may pop out somthing in the way it heat cycles or sets.It might be worth a pan drop and a look-see.
Re: Transmission troubles? [Re: John_Kunkel] #87437
07/13/08 10:59 PM
07/13/08 10:59 PM
IL
71dusta Offline OP
71dusta  Offline OP
IL
yes reverse is working great. Actually today I took it out again and it shifts into third fine until it warms up and the engine and trans only get to 180 degrees. Not sure why I lose it after it warms up?
Re: Transmission troubles? [Re: 71dusta] #87438
07/14/08 02:24 AM
07/14/08 02:24 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
have you rechecked your fluid level in NETURAL ON LEVEL GROUND ?
what did you use for fluid ?
Re: Transmission troubles? [Re: calrobb2000] #87439
07/14/08 03:22 AM
07/14/08 03:22 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I had a simular problem. lost third about 200 miles from home. I removed the valve body, tore it apart, and found one of the fluid channels inside had cracked. Some brake cleaner cleaned the valve body and some JB weld epoxy fixed the cracked fluid channel. The repair actually got me home and even lasted the month or so until I replaced the valve body.
Re: Transmission troubles? [Re: 71dusta] #87440
07/14/08 03:23 PM
07/14/08 03:23 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There is some leakage in the front clutch that only causes a problem when the fluid warms up and thins out.
Reverse also uses this clutch but the line pressure is boosted in Reverse so the leakage won't always cause problems like it does in 3rd.
Re: Transmission troubles? [Re: John_Kunkel] #87441
07/17/08 09:13 AM
07/17/08 09:13 AM
IL
71dusta Offline OP
71dusta  Offline OP
IL
checked fluid, its ok, took out and drove in drive and watched the temp come up and then when it got to normal operating temp it started slipping out of third gear again
Re: Transmission troubles? [Re: 71dusta] #87442
07/17/08 02:05 PM
07/17/08 02:05 PM
Marine Corps Base Hawaii
DemonKyle Offline
USMC LCPL
DemonKyle  Offline
USMC LCPL
Like John said, check the front clutch.
