any one ever spin a rod bearing ?? this is a fresh motor and i had rods sized but i think they goofed up # 5 spun in the rod and gabbed # 6 and it to spun dont look as bad #5 thin as paper crank has some small scatches in it . my q is can i file the rod cap some to increas the crush some i put a new bearing in and it fits good and no blueing of rods or crank i think couse of the oil i use ,,,,,rotela t it has zink in it can i file the caps or will it be out of round ? can i rebearing it and how bad do scatches fine ones hert?
