The window net thread! #873348
12/07/10 12:03 AM
12/07/10 12:03 AM
U.S.
moparniac Offline OP
U.S.
I'd appreciate it if my mopar brothers could post some pics of your setups! I have door bars that are removable and I kinda like the nets that are angled down along the door bar... Any and all setup pics are appreciated!
Mopar Performance
Re: The window net thread! [Re: moparniac] #873349
12/07/10 12:13 AM
12/07/10 12:13 AM
Tallmadge, Ohio
Butch Offline
Butch  Offline
Tallmadge, Ohio
Mine..............
'74 Duster 440
'04 Hemi Quad Cab Ram
'06 Pacifica
'78 MGB
Re: The window net thread! [Re: moparniac] #873350
12/07/10 12:31 AM
12/07/10 12:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
RJS will make any custom shape you want... just send
them a template (cardboard is fine) showing where you
want the rods going through... I dont think I have a
pic but mine follows the door bar most of the way down
then hooks to the top bar with a seat belt lock...
I;m going to change the top rear mount and putting
on a pivot point so it will just swing down
Re: The window net thread! [Re: MR_P_BODY] #873351
12/07/10 03:12 AM
12/07/10 03:12 AM
Russiaville, IN
mopar376d Offline
mopar376d  Offline
Russiaville, IN
Anyone run a mesh net? Thinking about buying one because I have a hard time looking through the regular ones....
Why does divorce cost so much? Because it is worth it!!!!!
Re: The window net thread! [Re: mopar376d] #873352
12/07/10 04:32 AM
12/07/10 04:32 AM
NHRA outlaw the string mesh or fishnet type nets years ago, ribbon SFI approved only now, if your going to run at a NHRA sanction track. Check your local track rules before deciding
Re: The window net thread! [Re: Cab_Burge] #873353
12/07/10 08:58 AM
12/07/10 08:58 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
NHRA still accepts mesh however the mesh has a dated life of two years while the ribbon never needs replacing
SFI 27.1 Window Net (Mesh) . . . 2 years
home of the
Sox and Martin Hemi Duster
Re: The window net thread! [Re: HEMIFRED] #873354
12/07/10 09:17 AM
12/07/10 09:17 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
These are the Mesh nets that are leagal, but as previously stated have a two year date on them, while ribbon has no exp date.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: The window net thread! [Re: Cab_Burge] #873355
12/07/10 11:20 AM
12/07/10 11:20 AM
U.S.
U.S.
I like the one butch posted! Is there some sort of mounting kit you buy or does it all come with the netting? Thz
Mopar Performance
Re: The window net thread! [Re: moparniac] #873356
12/07/10 11:44 AM
12/07/10 11:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Mounting kits are separate... RJS also has the kit
Re: The window net thread! [Re: moparniac] #873357
12/07/10 06:46 PM
12/07/10 06:46 PM
Tallmadge, Ohio
Butch Offline
Butch  Offline
Tallmadge, Ohio
Thanks, mine is an RJS custom order. Just send them a drawing of your dimensions and they'll send it an a couple of days depending where you live. The cost was just a few $ more than a standard one. Installation kit is from Summit.
Butch
'74 Duster 440
'06 Pacifica
'78 MGB
