70 E-Body Dana 60 rear endquestion #87333
07/11/08 06:38 PM
07/11/08 06:38 PM
Anonymous OP
Anonymous OP
The first question is what size Brake drums and backing plates came stock from the factory on a Feb build date, 1970 Hemi Cuda, Dana rear end. Second question, would they be the same as on a track pack equipped 1970 Hemi Cuda or would the brakes have been bigger? Such as 10.5 on normal 70 hemi cuda and 11" on track Pack 70 Hemi Cuda. Please be as exact as you can. I appreciate it. Thank you.
Re: 70 E-Body Dana 60 rear endquestion #87334
07/11/08 10:00 PM
07/11/08 10:00 PM
Sacramento,California
JRepucci Offline
JRepucci  Offline
3.54 could have either or.... does the car have power disc brakes?
4.10 cars all had 10.5 inch rear brakes in 1970
Re: 70 E-Body Dana 60 rear endquestion [Re: JRepucci] #87335
07/11/08 10:34 PM
07/11/08 10:34 PM
Anonymous OP
Anonymous OP
What sizes of backing plates and brake drums were available on the Dana 60 rear ends. Were there 10", 10.5", 11"?
If I understand correctly, the 1970 Hemi Cuda with a 4.10 Dana Track Pack would have come from the factory with 10" backing plates and matching brake drums. Is this correct? Exactly where are the measurements taken at?
Thanks,
Re: 70 E-Body Dana 60 rear endquestion #87336
07/12/08 01:16 PM
07/12/08 01:16 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Supertrack pak had front discs and rear 10 inch brakes along with a 4.10. Track Pack had 11 inch drums all around with a 3.54 ratio. Did the car come with front discs?
I always got a kick out of a 4.10 gear car that was good for 120MPH maxed out had the discs while the 3.54 gear that could easily pull 140MPH had the drums.
Sheldon
Re: 70 E-Body Dana 60 rear endquestion [Re: RUNCHARGER] #87337
07/12/08 01:22 PM
07/12/08 01:22 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
As far as I know, all hemi E-bodies came with disc brakes, therfore they should have 10 x 2 1/2" rear drums.
Re: 70 E-Body Dana 60 rear endquestion [Re: DoctorDiff] #87338
07/14/08 01:01 PM
07/14/08 01:01 PM
JRepucci Offline
JRepucci  Offline
Quote
3.54 4spd cars, 3.23 and 3.55 auto cars could have 4 wheel drum brakes. 11” finned drums
Re: 70 E-Body Dana 60 rear endquestion [Re: JRepucci] #87339
07/15/08 05:55 AM
07/15/08 05:55 AM
eganville ont
440beep Offline
440beep  Offline
eganville ont
082 - 3.54 s/g, Dana 60, 11" rear & front drums, (A33 Pkg)
083 - 3.54 s/g, Dana 60, 10" rear drum - front disc, (A33 Pkg)
084 - 4.10 s/g, Dana 60, 10" rear drum - front disc, (A32/A34 Pkg)
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: 70 E-Body Dana 60 rear endquestion [Re: JRepucci] #2882649
02/01/21 12:12 AM
02/01/21 12:12 AM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
Could they be finned drums
