Felpro # for 8.75 Axle flange gaskets needed #873172
12/06/10 08:29 PM
12/06/10 08:29 PM
WI
W
wannadrag Offline OP
W
WI
Need the felpro part # for the tin backside and foam front side gaskets for the 8.75 rear axle flange.
Re: Felpro # for 8.75 Axle flange gaskets needed [Re: wannadrag] #873173
12/06/10 08:48 PM
12/06/10 08:48 PM
California
P
polkat Offline
mopar addict
polkat  Offline
mopar addict
P
California
Don't know the number but I've always just used red RTV everywhere. Has always worked fine.
Re: Felpro # for 8.75 Axle flange gaskets needed [Re: wannadrag] #873174
12/06/10 09:27 PM
12/06/10 09:27 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
You can't get the foam gasket from Felpro , no longer available , member 71TA makes the foam gasket, I don't have the tin gasket number handy
Re: Felpro # for 8.75 Axle flange gaskets needed [Re: wannadrag] #873175
12/06/10 09:46 PM
12/06/10 09:46 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
part #13800. Shows as still a good number on the fel-pro website, and it is still listed on rockauto.com.
http://www.fme-cat.com/Part.aspx?pn=13800
Re: Felpro # for 8.75 Axle flange gaskets needed [Re: twodoorpost] #873176
12/06/10 11:49 PM
12/06/10 11:49 PM
BDW Offline
BDW  Offline
Backing plate gaskets (metal) Felpro 55032 $1.10
Backing plate gaskets (foam) Felpro 13800 $0.94
Inner Axle seals Timken 8695S $8.00
Outer Axle seals Timken 8704S $9.00
Re: Felpro # for 8.75 Axle flange gaskets needed [Re: BDW] #873177
12/07/10 03:17 PM
12/07/10 03:17 PM
WI
W
W
WI
The #55032 and #13800 are available.Just ordered them from Advance Auto Parts
