5/8 Stud Lugs for Weld Pro Star Rims anyone? #872683
12/06/10 09:49 AM
12/06/10 09:49 AM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
Does anyone make an open end 5/8 stud lug for Weld Pro Star wheels?
RS23L7 4-Speed
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: Mopar_Mike] #872684
12/06/10 10:40 AM
12/06/10 10:40 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
What's an open end stud?
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: The Shadow] #872685
12/06/10 10:56 AM
12/06/10 10:56 AM
Danville, NH
Danville, NH
Sorry, I meant open end lug..
RS23L7 4-Speed
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: Mopar_Mike] #872686
12/06/10 11:31 AM
12/06/10 11:31 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
ya mean lug nuts
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: smokinwoody] #872687
12/06/10 11:36 AM
12/06/10 11:36 AM
Danville, NH
Danville, NH
uhm.. ya.. I am such a lug-head sometimes..
RS23L7 4-Speed
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: Mopar_Mike] #872688
12/06/10 11:58 AM
12/06/10 11:58 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
If you bought the moroso or Comp engineering kit then they should of came with the nut's and aluminum spacers.
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: dartman366] #872689
12/06/10 12:03 PM
12/06/10 12:03 PM
Danville, NH
Danville, NH
I did not buy the kit, the studs came on the axles I bought. Is that how the 5/8th work tho? There is an aluminum spacer that fits on the stud, inside the wheel and then a small acorn lug nut? I have seen those with some kits.
RS23L7 4-Speed
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: Mopar_Mike] #872690
12/06/10 12:06 PM
12/06/10 12:06 PM
tboomer Offline
tboomer  Offline
Who made the axles? They should be able to supply the lug nuts...
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: tboomer] #872691
12/06/10 12:11 PM
12/06/10 12:11 PM
Danville, NH
Danville, NH
Strange..
RS23L7 4-Speed
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: Mopar_Mike] #872692
12/06/10 12:16 PM
12/06/10 12:16 PM
tboomer Offline
tboomer  Offline
I think Doctor Diff {Cass} is a Strange dealer...He might be able to find something for ya!
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: Mopar_Mike] #872693
12/06/10 12:16 PM
12/06/10 12:16 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Mike,
The 5/8 studs are the same size as the holes in the weld wheels. The aluminum spacer goes against the wheel and then an open-ended nut goes on.
Here is a pic of my axles with a 5/8 stud kit. They usually have 2 sets of spacers, long and short, you only need one set, generally the short ones with the weld wheels.
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: ProStDodge] #872694
12/06/10 12:23 PM
12/06/10 12:23 PM
Danville, NH
Danville, NH
Mike,
I see, thanks for the info/pic.
RS23L7 4-Speed
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: Mopar_Mike] #872695
12/06/10 12:24 PM
12/06/10 12:24 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
yes and yes...on your Star's the wheel will fit EXACTLY on those studs with little room to spare...then the spacers, then the lug nut over it tightened down of course...thats why they dont use a shoulder type of Lug Nut
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: smokinwoody] #872696
12/06/10 12:45 PM
12/06/10 12:45 PM
Danville, NH
Danville, NH
Should I use a jam nut after the lug nut? or is it not necessary?
RS23L7 4-Speed
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: Mopar_Mike] #872697
12/06/10 12:55 PM
12/06/10 12:55 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
just torque it down...retorque after a few miles
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: smokinwoody] #872698
12/06/10 01:24 PM
12/06/10 01:24 PM
ProStDodge Offline
ProStDodge  Offline
With 5/8 studs and weld wheels I recommend 135 ft/lb torque
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: ProStDodge] #872699
12/06/10 03:30 PM
12/06/10 03:30 PM
Danville, NH
Danville, NH
It is also not a good idea to use wheel spacers or is ok?
RS23L7 4-Speed
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: Mopar_Mike] #872700
12/06/10 03:38 PM
12/06/10 03:38 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I wouldn't use any spacers and you can get the open ended lug nits and spacers from Mark Williams.
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: ProStDodge] #872701
12/06/10 04:11 PM
12/06/10 04:11 PM
indiana
ss/ah3480 Offline
ss/ah3480  Offline
indiana
holes in wheels are 11/16...
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: ss/ah3480] #872702
12/06/10 08:10 PM
12/06/10 08:10 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Mike,
If you got the strange 5/8" studs, they look like long bolts that thread in from the inside of the axle flange and you will need the threaded sleeve that goes with them. The strange set up is different than mark williams set up. MW has a stud that is threaded on each end with a shoulder (11/16 to match the hole in the wheel.
If your studs look like a bolt that is threaded all the way, check on stanges web site for the sleeves. The sleeves make up the diffence in the 5/8" stud and the 11/16" hole in the wheels.
Brian Dunnigan
