5/8 Stud Lugs for Weld Pro Star Rims anyone?
#872683
12/06/10 09:49 AM
12/06/10 09:49 AM
Posts: 4,283 Danville, NH
Mopar_Mike
Danville, NH
Does anyone make an open end 5/8 stud lug for Weld Pro Star wheels?
RS23L7 4-Speed
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone?
[Re: smokinwoody]
#872687
12/06/10 11:36 AM
12/06/10 11:36 AM
Mopar_Mike
Danville, NH
uhm.. ya.. I am such a lug-head sometimes..
RS23L7 4-Speed
[Re: Mopar_Mike]
#872693
12/06/10 12:16 PM
12/06/10 12:16 PM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
Mike,
The 5/8 studs are the same size as the holes in the weld wheels. The aluminum spacer goes against the wheel and then an open-ended nut goes on.
Here is a pic of my axles with a 5/8 stud kit. They usually have 2 sets of spacers, long and short, you only need one set, generally the short ones with the weld wheels.
[Re: Mopar_Mike]
#872695
12/06/10 12:24 PM
12/06/10 12:24 PM
Posts: 12,339 somwhere
smokinwoody
somwhere
If you bought the moroso or Comp engineering kit then they should of came with the nut's and aluminum spacers.
I did not buy the kit, the studs came on the axles I bought. Is that how the 5/8th work tho? There is an aluminum spacer that fits on the stud, inside the wheel and then a small acorn lug nut? I have seen those with some kits.
yes and yes...on your Star's the wheel will fit EXACTLY on those studs with little room to spare...then the spacers, then the lug nut over it tightened down of course...thats why they dont use a shoulder type of Lug Nut
[Re: smokinwoody]
#872696
12/06/10 12:45 PM
12/06/10 12:45 PM
Mopar_Mike
Danville, NH
Should I use a jam nut after the lug nut? or is it not necessary?
RS23L7 4-Speed
[Re: ProStDodge]
#872699
12/06/10 03:30 PM
12/06/10 03:30 PM
Mopar_Mike
Danville, NH
It is also not a good idea to use wheel spacers or is ok?
RS23L7 4-Speed
