Re: Power brakes converted to Manual
[Re: saukvillage]
#87227
07/12/08 09:34 AM
07/12/08 09:34 AM
Posts: 363 Simi Valley, CA
splatt
super street
super street
Simi Valley, CA
The only new parts are an adjustable brake push rod, a new master cylinder with the correct size bore, and a firewall stiffening plate.
The booster and cureent brake push rod and linkage will be removed. The new push rod bolts straight to the brake pedal arm in a different hole than the old linkage.
The firewall stiffening plate from a manual brake car is best, but your existing one (attached to the back of the booster) can be cut to work.
73 Challenger, 360 auto, a work in progress
[Re: saukvillage]
#87229
07/22/08 07:24 AM
07/22/08 07:24 AM
Posts: 8,926 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Really !?!?! Tell me more about this different hole. Where is it located and what's the reason for the different hole? Did a similar swap years ago but wasn't aware of the different hole.
Much appreciated.
