Re: Broke Rocker Arm Rod ?????? 70 RR 383
[Re: okie]
#871977
12/05/10 03:17 PM
12/05/10 03:17 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I had that happen a long time ago to a 383, the bolts for the shaft had worked loose, (leftover glassbeads in the bolt hole from cleaning) caused a incorrect torque reading. Anyway, Loss of oil pressure was the first clue something was wrong, Thre were no parts or pieces to get into the motor. No damage to my motor. Bottom line #1 concern is loss of oil pressure..
[Re: MoparforLife]
#871979
12/05/10 03:30 PM
12/05/10 03:30 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Unless a lifter pops out then al the oil pressure dumps right out, BTDT
[Re: Supercuda]
#871982
12/05/10 10:54 PM
12/05/10 10:54 PM
sthemi
Chicago Burbs
When the shaft breaks, it is like opening a giant drain on oil pressure, the pump doesnt make enough flow to maintain pressure..same as when a liter pops out. There should be no valve damage, unless a stuck valve caused the damage, not a loose bolt.. Ususlly the pushrod will bend before the shaft breaks..
[Re: okie]
#871987
12/06/10 08:46 PM
12/06/10 08:46 PM
Posts: 679 N.E Indiana
repad
super street
super street
N.E Indiana
So you don't think it should have hurt my pistons are rings? I didn't know what it would have done on the 2 cylinders the rockers wasn't working on. It never lost oil pressure and I didn't drive it that far. I torgued all the bolts to the specs but 1 of them came loose and 1 broke in the head but I got it out so I'm waiting for the new parts to get here Tues. So maybe it won't be nothing bad. Ronnie
Check that you used the corect length rocker shaft bolts, possibly the bolt that you broke was bottoming out in the hole. If the shaft was not held down properly, it may have allowed it to flex and crack.
