Extreme altitude #870283
12/03/10 01:54 PM
12/03/10 01:54 PM
North Carolina
sasquatch Offline OP
North Carolina
Does anyone here have real world knowledge of tuning engines at 11,000 to 12,000 feet? I have a customer in South Africa that seems to be having some trouble with a 572 hemi. Most of the advise that works here does not seem to be working there.
Todd
Re: Extreme altitude [Re: sasquatch] #870284
12/03/10 02:19 PM
12/03/10 02:19 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
11,000 + feet??? That guy needs to get tuning advice from NASA for that sort of altitude.
Re: Extreme altitude [Re: sasquatch] #870285
12/03/10 02:27 PM
12/03/10 02:27 PM
organ
maximum entropy Offline
organ
Todd
boat racer, prolly.
Re: Extreme altitude [Re: maximum entropy] #870286
12/03/10 02:30 PM
12/03/10 02:30 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Less fuel, a lot less fuel!
Re: Extreme altitude [Re: maximum entropy] #870287
12/03/10 02:30 PM
12/03/10 02:30 PM
North Carolina
North Carolina
Actually it is in a 69 Charger.Todd
Re: Extreme altitude [Re: sasquatch] #870288
12/03/10 02:41 PM
12/03/10 02:41 PM
Less fuel and more timing, is it dry or real humid where he is at? If more than 50% humidity lean it out some more than if it is dryer than 50%. Quality of fuel is a player also. Flying taught me that a 540 C.I. N/A airpalne motor will make 55% of its sea level power at 12000 ft leaned out to 75 degrees EGT rich of peak in standard atomsphere, less if hotter and less B.P., worse if humid also IHTHs
Re: Extreme altitude [Re: sasquatch] #870289
12/03/10 02:42 PM
12/03/10 02:42 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I run 7000-9000 corrected all summer and jet my 1150 dom. at 86's square instead of 92-94's. I also run 33* instead of 31* timing,
Re: Extreme altitude [Re: camastomcat] #870290
12/03/10 02:50 PM
12/03/10 02:50 PM
North Carolina
North Carolina
Actually one of the problems seems to be boiling the Trans fluid. I sent him a Dynamic 9.5 that I have used a ton and it boils the fluid in around town driving WITH a big cooler. With a 12 inch converter and a 572 hemi it seems to run around 185. But who wants to run a 2400 stall with a 572 hemi???
Todd
Re: Extreme altitude [Re: sasquatch] #870291
12/03/10 03:09 PM
12/03/10 03:09 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Todd, EFI would be the way to go. If not, The air bleeds woudl have to be closed up a bit. Does it have a power valve? If so, it would have to come in at a lower signal.
Hope this helps
8.30's @3400 lbs
Re: Extreme altitude [Re: sasquatch] #870292
12/03/10 03:36 PM
12/03/10 03:36 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
Todd
Thats odd...I have a hard time boiling potatoes at my cabin at 8500 ft...water takes up to 30 minutes to boil up there....LOL
Re: Extreme altitude [Re: Chassisman] #870293
12/03/10 03:58 PM
12/03/10 03:58 PM
organ
organ
Todd
you need more btu's! and double (or triple) your cooking times! we used to put our fingers in boiling water on our climbing expeditions! even here in bend (~3600 ft) it boils at about 200°.
Re: Extreme altitude [Re: Chassisman] #870294
12/03/10 10:19 PM
12/03/10 10:19 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Todd
With less atmospheric pressure water boils easier at a lower temp. Maybe your fire doesnt have enough oxygen to create enough heat/btu,s,
High atmosphere = way less fuel.
Small airplanes have a lean out valve you adjust the higher it climbs. Kind of like a choke cable thingy but instead of choking air your choking fuel. mike
Re: Extreme altitude [Re: Sport440] #870295
12/03/10 10:44 PM
12/03/10 10:44 PM
UK
602heavy Offline
602heavy  Offline
UK
Must be something to do with the atoms.
Gotta love that second post by Budget.
Re: Extreme altitude [Re: 602heavy] #870296
12/03/10 10:56 PM
12/03/10 10:56 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
pretty sure what you're running into is the main (only?) reason WWII fighters had some form of forced induction on them.
Re: Extreme altitude [Re: Kevins493] #870297
12/03/10 11:02 PM
12/03/10 11:02 PM
UK
602heavy Offline
602heavy  Offline
UK
Some high altitude world war two planes ran the bottle.
Re: Extreme altitude [Re: sasquatch] #870298
12/03/10 11:14 PM
12/03/10 11:14 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Todd, I dont know whats happening with your tranny fluid. I doubt its boiling as that would require a temp of about 800 + degrees witch by the way is its approximate auto ingnite temp.
My guess is its foaming up for some reason, lack of fill maybe While 12000 ft. is high enough to have a effect on A/F its not that high IMO to have any major effects on the tranny or engine oil fluids.
I could be wrong about that though. mike
Re: Extreme altitude [Re: Sport440] #870299
12/04/10 01:57 AM
12/04/10 01:57 AM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: Extreme altitude [Re: Kevins493] #870300
12/04/10 02:04 AM
12/04/10 02:04 AM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
The power problem is mixture comtrol probably to rich. The reason WW2 fighters had boosted engines was as Cab said at 12000 ft you're down to 55% power. It's really hard to dogfight with no power!
The bombers had boost to get high enough to fly over the FLAK.
Re: Extreme altitude [Re: 602heavy] #870301
12/04/10 02:05 AM
12/04/10 02:05 AM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
Can you provide an example?
Re: Extreme altitude [Re: Chassisman] #870302
12/04/10 02:27 AM
12/04/10 02:27 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
