Re: Extreme altitude
[Re: sasquatch]
#870291
12/03/10 03:09 PM
12/03/10 03:09 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
Todd, EFI would be the way to go. If not, The air bleeds woudl have to be closed up a bit. Does it have a power valve? If so, it would have to come in at a lower signal.
Hope this helps
8.30's @3400 lbs
[Re: sasquatch]
#870292
12/03/10 03:36 PM
12/03/10 03:36 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
Actually one of the problems seems to be boiling the Trans fluid. I sent him a Dynamic 9.5 that I have used a ton and it boils the fluid in around town driving WITH a big cooler. With a 12 inch converter and a 572 hemi it seems to run around 185. But who wants to run a 2400 stall with a 572 hemi??? Todd
Thats odd...I have a hard time boiling potatoes at my cabin at 8500 ft...water takes up to 30 minutes to boil up there....LOL
[Re: Chassisman]
#870294
12/03/10 10:19 PM
12/03/10 10:19 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
With less atmospheric pressure water boils easier at a lower temp. Maybe your fire doesnt have enough oxygen to create enough heat/btu,s,
High atmosphere = way less fuel.
Small airplanes have a lean out valve you adjust the higher it climbs. Kind of like a choke cable thingy but instead of choking air your choking fuel. mike
[Re: sasquatch]
#870298
12/03/10 11:14 PM
12/03/10 11:14 PM
Sport440
Canton, Ohio
Todd, I dont know whats happening with your tranny fluid. I doubt its boiling as that would require a temp of about 800 + degrees witch by the way is its approximate auto ingnite temp. My guess is its foaming up for some reason, lack of fill maybe While 12000 ft. is high enough to have a effect on A/F its not that high IMO to have any major effects on the tranny or engine oil fluids. I could be wrong about that though. mike
