They are good - like others said, avoid the Dynalites for long term durability on the street.
If you want a good deal, contact Frank at Prodigy...
Prodigy Customs He hooked me up with four wheel 14" disks, 6 piston front and 4 piston rears with integrated parking brake.
I have the alterkation - which is mustang II spindles and that really opens up options on lower cost brakes.
I also had him spec out my Moser 60 with Ford big ends on it for the same reason.
I could get larger brakes, more varieties and lower cost.
I will go on the record to say my brakes are total over kill and not needed. My primary reason for for asthetic purposes when using my Forgeline 18" wheels...
