Re: 5 speed pricing info
[Re: astjp2]
#868039
02/04/11 01:08 PM
02/04/11 01:08 PM
Posts: 869 Sugarloaf, PA. USA
JamiePasson
Sugarloaf, PA. USA
We do have a waiting list. Tom is right, it is growing. This is comforting knowing that we have some support for this HUGE chance we are taking here. As for the Inland handle. I will attempt to make a modified tower for the Inland handle. If it works, great, if not, hey we tried. As for an Inland shifter ball with the correct shift pattern, You guys are on your own there! Jamie
[Re: JamiePasson]
#868040
02/10/11 03:07 PM
02/10/11 03:07 PM
Posts: 75,400 A gulag near you.
JohnRR
A gulag near you.
Jamie there is an adapter already available , it should work if an original handle with fit the new shifter .
[Re: Ply72rr]
#868042
02/12/11 12:30 AM
02/12/11 12:30 AM
Posts: 905 SD
zrxkawboy
SD
Yes, really enjoyed the article.
It's Swifty! Swifty, you toad sucker!
[Re: lilcuda]
#868045
03/08/11 11:35 AM
03/08/11 11:35 AM
JamiePasson
Sugarloaf, PA. USA
lilcuda, The bolts are not helicoiled. There is no need to do this. The aluminum that we are using of good. PLUS, no one should be turning bolts in and out on it. Disassembly mean NO WARRANTY. We will be working on fitment of the '64-66 A body cars next. Thanks, Jamie
[Re: lilcuda]
#868048
03/10/11 06:29 PM
03/10/11 06:29 PM
JohnRR
A gulag near you.
Jamie,
I have no intention of disassembling the trans if I buy one, but if I remember correctly, in order to get the trans into and out of an early a body, you have to take the shifter off. It's been 15 years since I had mine out, so my memory might be foggy. I was just concerned about wear of the bolt holes in the event the shifter does need to come off to R & R the trans.
How do I get on the list to find out when you will have a trans that fits the early a?
Thanks!
Do you have to remove the shifter mounting plate to get the trans out of the car ?
[Re: JohnRR]
#868052
03/26/11 02:05 PM
03/26/11 02:05 PM
Posts: 701 Northern California
lilcuda
Northern California
I don't think so. I forgot about that. Been a while since I had the trans out (15+ years!)
[Re: OLD318]
#868053
03/30/11 03:28 PM
03/30/11 03:28 PM
JohnRR
A gulag near you.
Sorry, I have'nt read all the posts here... Are you offering Big block and small block bell housings in the kits or are those going to be separate costs?
Also I keep hearing A-Body and E-Body... Are there going to be 68-74 B-Body kits? For both Big block and Small block available (all years 68-74)?
It uses the stock bellhousing so if you already have a car set up for manual trans it will bolt right in .
I'm pretty sure he has a 69 Down B body tail , 70 up B body uses the same tails as an E body .
[Re: JohnRR]
#868054
03/30/11 04:05 PM
03/30/11 04:05 PM
Posts: 6,445 Missouri
68KillerBee
Missouri
Gotta have the hemi 4 speed set up though to bolt right in (18 spline) i believe.
[Re: 68KillerBee]
#868055
04/01/11 02:08 PM
04/01/11 02:08 PM
JohnRR
A gulag near you.
That's just a clutch disc to change .
