Page 10 of 82 1 2 8 9 10 11 12 81 82
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867919
12/14/10 10:48 AM
12/14/10 10:48 AM
Sugarloaf, PA. USA
JamiePasson Offline OP
Sugarloaf, PA. USA
Side Shot
Passon Performance 309 Turkey Path Sugarloaf, PA 18249 (570) 401 8949 www.passonperformance.com
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867920
12/14/10 10:49 AM
12/14/10 10:49 AM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
other side
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867921
12/14/10 10:50 AM
12/14/10 10:50 AM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
Bottom shot
Re: New Passon Performance 5 Speed update [Re: JohnRR] #867922
12/14/10 10:57 AM
12/14/10 10:57 AM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
Jamie , couple of questions , I know they won't get answered till next week .
1) What mount location will the B/E trans have , I assume the 70 up location? I never bought your B/E tail for the alum case I bought.
2) If someone bought say the A body trans and wanted to change it at a later date to the B/E would it be possible to buy a mainshaft and tailhousing, or send it in to have it retro fitted ?
John,
The B/E tail will be the same arrangement as the factory B/E tail. Front and rear shifter mount flange with frontward trans mount flange. The '64- '69 B tail will be like factory too. Single shifter mount flange with trans mount flange rearward slightly.
If someone needs to swap tails later. We will swap it for them.
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867923
12/14/10 10:57 AM
12/14/10 10:57 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
The speedometer cable will hook up on the passenger side? Am I seeing that correctly?
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867924
12/14/10 10:59 AM
12/14/10 10:59 AM
eastern,Ky
70RT Charger Offline
eastern,Ky
No matter what I think about the price that Tranny is absolutely beautiful!
Re: New Passon Performance 5 Speed update [Re: 70RT Charger] #867925
12/14/10 01:12 PM
12/14/10 01:12 PM
waukon iowa
1hot68 Offline
1hot68  Offline
waukon iowa
Where is the b/u light switch located?
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867926
12/14/10 01:53 PM
12/14/10 01:53 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
John,
That's interesting , I didn't expect you to do both early and late B tails
edit, I see the speedo is on the other side of the tailshaft ? will a factory cable reach that point without getting melted on the exhaust or is there some sort of cable extender ?
Re: New Passon Performance 5 Speed update [Re: JohnRR] #867927
12/14/10 02:31 PM
12/14/10 02:31 PM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
Thank you for the kind words.
There will be a speedo cable extension with a male end (just like the thread on the speedo housing.) The other end of the cable will be the large nut on it that will screw onto YOUR speedo housing. You will transfer your housing and gear from your existing trans into this one.
The backup switch is located under the front of the sidecover near the drain plug. It takes a stock Mopar switch. Your factory harness and plug will reach and work with no problem.
Thanks,
Jamie
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867928
12/14/10 11:26 PM
12/14/10 11:26 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Excellent Jamie , now the decision , remodel my bathroom or buy this trans.
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867929
12/14/10 11:39 PM
12/14/10 11:39 PM
Nampa, ID
MadMatt Offline
MadMatt  Offline
Nampa, ID
Just a quick question. Does the '70 A-body use the same trans cross-member for both auto and manual applications or is it different?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: New Passon Performance 5 Speed update [Re: JohnRR] #867930
12/15/10 08:49 AM
12/15/10 08:49 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
john, please leave your man card at the exit for even considering this!
Jamie - Great Job!
Re: New Passon Performance 5 Speed update [Re: DJVCuda] #867931
12/15/10 09:39 AM
12/15/10 09:39 AM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
When can we expect to be able to buy one? if I can get mine before the MATS I might actually drive there this year !
Re: New Passon Performance 5 Speed update [Re: ogopogo] #867932
12/15/10 10:24 AM
12/15/10 10:24 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Good idea, have him ship it to me, save the customs BS and we can install it at my place before you head down
Re: New Passon Performance 5 Speed update [Re: ogopogo] #867933
12/15/10 10:32 AM
12/15/10 10:32 AM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
We are feverishly working to get the A Body tail revisions and the B, B/E tails finished up here. It looks like that is a major delay. We are looking into another foundry right now as well. I like the foundry we are using but turnarounds are rediculously slow. MATS is probably gonna be pushing it. We will do our best.
Thanks,
Jamie
Re: New Passon Performance 5 Speed update [Re: JohnRR] #867934
12/15/10 10:37 AM
12/15/10 10:37 AM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
John,
Seriously...? I have a 5 gallon bucket that you can crap in!
Re: New Passon Performance 5 Speed update [Re: JohnRR] #867935
12/15/10 02:15 PM
12/15/10 02:15 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
If you are married, the decision has already been made for you.
Re: New Passon Performance 5 Speed update [Re: JohnRR] #867936
12/15/10 06:59 PM
12/15/10 06:59 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Way I look at it the economy is very tough and the bath remodel will cost more than the trans. So you have my permission to save money and do the right thing. lol.
Jammie, looks like a great product that will fit my needs. Thnaks!
Damon
Re: New Passon Performance 5 Speed update [Re: mopardamo] #867937
12/15/10 08:22 PM
12/15/10 08:22 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I've been waiting for this Jamie, as you know I almost pulled the trig on the OD 4 speed but I needed the right gear for 1/4 mile. My 517 70 Charger has a 727 in it but I left the clutch pedal in it to make the swap back easy....will it stand 700hp? Do you have any running around yet behind max wedge strokers?
I know a Tremec will hold up behind my motor but I know from plenty of experience rowing tremecs that it wont shift well at all behind a high torque but also hyper-fast revving combo like mine.
I can't imagine letting go of a matching numbers 833 case in my own situation (just to offset the cost of the new one) but I'd be willing to pull the trig on something like that if I was certain it would hold up and shift well under the load of a big motor.
WIZE
In Car:
Re: New Passon Performance 5 Speed update [Re: mopardamo] #867938
12/15/10 08:23 PM
12/15/10 08:23 PM
Brookville Pa
crowbait Offline
crowbait  Offline
Brookville Pa
home values are way down...putting that money into your home right now would be a poor financal decision. buy a tranny and sleep better at night.
