Re: New Passon Performance 5 Speed update
[Re: JohnRR]
#867922
12/14/10 10:57 AM
12/14/10 10:57 AM
Posts: 869 Sugarloaf, PA. USA
JamiePasson
Sugarloaf, PA. USA
Jamie , couple of questions , I know they won't get answered till next week .
1) What mount location will the B/E trans have , I assume the 70 up location? I never bought your B/E tail for the alum case I bought.
2) If someone bought say the A body trans and wanted to change it at a later date to the B/E would it be possible to buy a mainshaft and tailhousing, or send it in to have it retro fitted ?
John, The B/E tail will be the same arrangement as the factory B/E tail. Front and rear shifter mount flange with frontward trans mount flange. The '64- '69 B tail will be like factory too. Single shifter mount flange with trans mount flange rearward slightly.
If someone needs to swap tails later. We will swap it for them.
[Re: JamiePasson]
#867929
12/14/10 11:39 PM
12/14/10 11:39 PM
Posts: 737 Nampa, ID
MadMatt
Nampa, ID
Just a quick question. Does the '70 A-body use the same trans cross-member for both auto and manual applications or is it different?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
[Re: JohnRR]
#867930
12/15/10 08:49 AM
12/15/10 08:49 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
Excellent Jamie , now the decision , remodel my bathroom or buy this trans.
john, please leave your man card at the exit for even considering this!
Jamie - Great Job!
[Re: ogopogo]
#867932
12/15/10 10:24 AM
12/15/10 10:24 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
When can we expect to be able to buy one? if I can get mine before the MATS I might actually drive there this year !
Good idea, have him ship it to me, save the customs BS and we can install it at my place before you head down
[Re: JohnRR]
#867934
12/15/10 10:37 AM
12/15/10 10:37 AM
JamiePasson
Sugarloaf, PA. USA
John, Seriously...? I have a 5 gallon bucket that you can crap in!
[Re: JohnRR]
#867935
12/15/10 02:15 PM
12/15/10 02:15 PM
Posts: 6,111 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
If you are married, the decision has already been made for you.
[Re: mopardamo]
#867937
12/15/10 08:22 PM
12/15/10 08:22 PM
Posts: 9,949 Weddington, N.C.
Streetwize
Weddington, N.C.
I've been waiting for this Jamie, as you know I almost pulled the trig on the OD 4 speed but I needed the right gear for 1/4 mile. My 517 70 Charger has a 727 in it but I left the clutch pedal in it to make the swap back easy....will it stand 700hp? Do you have any running around yet behind max wedge strokers?
I know a Tremec will hold up behind my motor but I know from plenty of experience rowing tremecs that it wont shift well at all behind a high torque but also hyper-fast revving combo like mine.
I can't imagine letting go of a matching numbers 833 case in my own situation (just to offset the cost of the new one) but I'd be willing to pull the trig on something like that if I was certain it would hold up and shift well under the load of a big motor.
