Page 7 of 81 1 2 5 6 7 8 9 80 81
Re: New Passon Performance 5 Speed update [Re: 1hot68] #867859
12/07/10 02:35 PM
12/07/10 02:35 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
This trans ain't for everybody. It's geared toward (pun intended) guys with original 4-speed cars so valuable that they can't modify them for a Tremec. Therefore the price is not an issue.
It's too high for me because I can't justify putting a $4300 trans in a $3000 C-body.
Re: New Passon Performance 5 Speed update [Re: Fury Fan] #867860
12/07/10 03:02 PM
12/07/10 03:02 PM
Sterling Heights, Michigan 483...
daniel_depetro Offline
x2!, only I have mostly A-bodies & B-bodies.
Being that you reuse your shifter handle and belhousing/flywheel/clutch set-up and what you are purchasing is the transmission itself and the specific operating hardware unique to this transmission only I was hoping for a ~$3,250.00 sticker price and was pretty much expecting $4,750.00. Heh.
it's a RACE box meaning I don't think it has syncros, not going to be street friendly.
Just an FYI if the Mcleod unit does turn out to be a bolt in unit they will be stiff competition as they claimed at SEMA the price of their unit will be around $3300 for the Mopar unit, but they are having a synchro problem at the moment from what they told me at SEMA and I heard from another source they are getting into some litigation over the gears.
I thought the McLeod transmission was not going to be street friendly because it had no synchros?!?!
I guess time will tell if the McLeod is everything they have been promising for years or if this RS600 surfaces.
Congrat's to Passon on a making what appears to be a solid product. I really like how it looks semi-original (enough to fool most), and how you use the correct shifter handle of the vehicle it goes into for that original look as well.
Too bad I don't own a forest full of money tress.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
Re: New Passon Performance 5 Speed update [Re: 1hot68] #867861
12/07/10 03:56 PM
12/07/10 03:56 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I dont know Jamie and never dealt with him but from the tone of his posts he is a true gentleman and someone that I will look to do business with in the future.
I have been collecting parts, information and pricing on two automatic to manual conversions over the past year. A 76 Corvette and a 1956 Dodge. I have a good idea of what things cost to do this swap yourself without buying a kit.
If you were going to use another 5 speed like a TKO and had to replace your bellhousing, clutch, driveshaft, install a hyd clutch setup, speedometer cable, crossmember, wiring, etc it will cost you about $2000. (I will share my T56 conversion spereadsheet with my research, prices an sources with anyone who wants it) plus $2200 for a TKO transmission. (maybe go with a T45 for about $1600 or so). So a bolt in swap that fits, does not require cutting, preserves original looks and can take high HP applications for the same cost is a GREAT deal.
It is a fact of life, manufacturing in expensive in the US and quality does not come cheap.
Here is an idea for Jamie............ go ahead and find a Chineese or Indian manufacturer and commission inexpensive knockoff and offer a second tier option. This way you can sell two, the first one when the customer wants to do it cheap, and a second one when they decide to do it right.
Scott
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: New Passon Performance 5 Speed update [Re: finadk] #867862
12/07/10 04:27 PM
12/07/10 04:27 PM
Is this transmission listed (or at least mentioned) on your website?
I can't seem to find it.
Re: New Passon Performance 5 Speed update [Re: finadk] #867863
12/07/10 06:13 PM
12/07/10 06:13 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
Scott
You're joking, right?
Also, you have China do it, they'll just steal the specs and then ProComp or Eagle will sell it as their own.
Re: New Passon Performance 5 Speed update [Re: 2fast4yourBrain] #867864
12/07/10 06:27 PM
12/07/10 06:27 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
Well all that they have to do is buy one and reverse engineer it like they do with everything else. If someone was inclined to copy the part its quite hard ($$$) to stop them. welcome to the Global economy.
Scott
Re: New Passon Performance 5 Speed update [Re: finadk] #867865
12/07/10 08:54 PM
12/07/10 08:54 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
Jamie, Thanks for posting the price and being so free with information that you as a manufacturer have absolutely NO obligation to share. I think it's a fair price considering. Some of us will just save our $$$. I hope the guys with the bucks step up bigtime and buy.
One thing I love about old mopars is the "Snick-Snick!" feel of the hurst shifter. I'd rather have that feel than the foreign feel of a modern T-5 trans and shifter.
I’m listening.
Re: New Passon Performance 5 Speed update [Re: Big Bad Bee] #867866
12/07/10 09:02 PM
12/07/10 09:02 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
+1, not many businessmen would do this. Though it's out of my price range, it appears to be a fair price. "Made in USA" is definitely worth something, and if I had the coin, I'd order one!
It's Swifty! Swifty, you toad sucker!
Re: New Passon Performance 5 Speed update [Re: finadk] #867867
12/07/10 09:39 PM
12/07/10 09:39 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I'm considering getting one and I have "just an a-body" the car is suppose to be fun and a 5-speed would be icing on the cake.
You only go around once and I don't find any of the other options appealing.
Re: New Passon Performance 5 Speed update [Re: gdonovan] #867868
12/07/10 10:09 PM
12/07/10 10:09 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
he could have said it was $2500, and people would still complain and say it's too much.....
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: New Passon Performance 5 Speed update [Re: Old School] #867869
12/07/10 10:35 PM
12/07/10 10:35 PM
warfordsburg, PA
dirt Offline
dirt  Offline
warfordsburg, PA
I have experience with jammie from back into the 90's and never had a bad experience. I believe this 5 speed will be a good unit and look forward to buying one as soon as i can.
The fact that he is sharing his cost with us here is something i dont even think anyone would expect him to do, no one else would have.
my opinion is that if someone thinks its too much just dont buy it. Thats what i tell everyone who complains about my parts.
When you do the best job you can building something and are honest about everything and some one complains its too much its easy to tell them to buy it some where else because you have nothing to hide and more than likely they are the ones who ,if you finally convinced them to buy it , would come back complaining and making life difficult because they are upset that they spent the cash on it and some how its your fault.
I have a T56 in one of my cars and have installed a tko 5 speed kit into a dart. I would still pick this 5 speed over both if it works like it sounds like it will.
just my opinion for what its worth
Re: New Passon Performance 5 Speed update [Re: dirt] #867870
12/08/10 12:05 AM
12/08/10 12:05 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
The people that would really benefit from this transmission are the people that already have an 18 spline box in the car now.There are so many guys out there with 4.10 gears in the rear that don't like to drive long distance because of cooling problems and or fuel consumption issues.Enter the Passon 5-speed now you can stab this tranny in your HEMI GTX with a 4.10 Dana and drive it ANYWHERE!
All you guys whining about transmission cost obviously haven't priced a "strong" gearbox that will take an extreme beating and still come back for more.
I put a Richmond in my car because there wasn't an option like this available at the time
I have over $3000 in the trans and all the stuff to make it work in my car with some extensive modifications to my torsion bar crossmember all of which all could have been avoided with this wonderful tranny
Now if I could only sell my Richmond to buy this new box
Thanks for all of your hard work and dedication to bring your vision to to life
Gus
64 Plymouth Savoy
Dana 60
Re: New Passon Performance 5 Speed update [Re: fourgearsavoy] #867871
12/08/10 01:11 AM
12/08/10 01:11 AM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
I just read through this entire post and I'm surprised how civil it has stayed. I almost choked on my Coke when I saw that the markup is only 10%. That is almost unheard of, most every other manufacturer would be at least 25%. When I worked at a Dodge dealer they added 10% to the RETAIL price.
Jamie has produced a top notch piece that fits without cutting and is Made in the USA, all I can say is GOOD JOB.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #867872
12/08/10 01:12 AM
12/08/10 01:12 AM
Nampa, ID
MadMatt Offline
MadMatt  Offline
Nampa, ID
Jamie, I've been gathering parts just in anticipation of the release of your tranny. Wish it cost less, but I think the price is fair and I will save up until I can afford one. (I think I will have the bucks by the time you actually release it in late spring.) I'm doing an auto to stick conversion on a '70 SB Dart. I'm going to need a clutch and flywheel. Can you give me some idea of what you would recommend and what the cost would be? I'm going to run a hydraulic system to actuate the stock fork and bearing. The motor makes 335 lb/ft and 317HP at the rear wheels. Might "grow" to 400 someday, but that's about it. Also, what are your thoughts on running an aluminum flywheel? It sees mostly street (and the occasional CA canyon) driving. Drag strip once or twice a year just for fun. Just trying to get a feel for what the total price is going to be.
Thanks!
Matt
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: New Passon Performance 5 Speed update [Re: MadMatt] #867873
12/08/10 01:31 AM
12/08/10 01:31 AM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
4300 wouldn't seem as bad if we hadn't given away all the good paying jobs for the masses to a place with ZERO standards for anything.
Compare to the cost of getting an 18 spline, getting it rebuilt, and this really isn't too bad for all new parts made where we value standards for many aspects of life and also take some pride in what we make. Or used to that is.
Re: New Passon Performance 5 Speed update [Re: SomeCarGuy] #867874
12/08/10 03:11 AM
12/08/10 03:11 AM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
People will spend thousands to eak out an extra 50-100hp.
I think if going from an automatic to this transmission, I'd rather have fun rowing my own than that extra 50-100hp. Your car would feel fast still, but be a lot of fun.
Re: New Passon Performance 5 Speed update [Re: SomeCarGuy] #867875
12/08/10 11:54 AM
12/08/10 11:54 AM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
I concur. I think if there's a viable alternative to a Chinese product that is made in America at a higher cost, we should always, within our means, go w/the more expensive, American product.
We need to support our fellow Americans; we'll be all better off.
The Wal-Mart mentality of buying everything as cheap as possible is destroying this country.
Re: New Passon Performance 5 Speed update [Re: 2fast4yourBrain] #867876
12/08/10 01:04 PM
12/08/10 01:04 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
is it going to be as noisy as your 4spd overdrives?
Re: New Passon Performance 5 Speed update [Re: Old School] #867877
12/08/10 06:36 PM
12/08/10 06:36 PM
eastern,Ky
70RT Charger Offline
eastern,Ky
Your wrong there,I would of took one for $3,000 but they would have went in the hole if they sold it for that
Re: New Passon Performance 5 Speed update [Re: 70RT Charger] #867878
12/08/10 07:11 PM
12/08/10 07:11 PM
I agree with the above statement.
$4,200.00 is a far cry from $2,500.00, but your opinion is noted.
I'm sure $2,500.00 is reasonable to almost anyone, but $4,200.00 is more then some of us have into some of our cars.
I'm not saying it isn't going to be the best choice for for restored Mopar. Just like everything else I buy I want to make sure I'm getting the maximum part per dollar spent that best suits my particular wants. Sometimes that means I don't need the best piece on the market.
I am not here to ruffle feathers or to play the flip side on every situation. I also apologize for going off topic now that this thread has been moved, but the whole buy American or nothing is getting a little old at times.
Don't get me wrong, I love and served for this great nation and given the choice between two products of similar quality/price I'll buy the American made product everytime.
But with (say) vehicles, why would I spend my hard earned money an inferior vehicle. It's no secret that the import vehicles are years ahead of the domestics in terms of pretty much everything. The good news is for the first time in a long time at least a couple of the domestics are waking up and starting to actually build some quality made products to compete globally again. My only gripe is when is Chrysler going to follow suit?
America needs to get back to making superior products that can compete at global prices. In my opinion we still have a ways to go.
