Trailer Inspection Near Pataskla OH...8 bolt axles ??? #867392
11/30/10 08:35 PM
11/30/10 08:35 PM
NW PA
V10nacuda Offline OP
NW PA
I am looking at a 26' Haulmark trailer near Pataskla OH. It has a 10k GVW but has 8 bolt wheels.
I thought 8 bolt wheels were 6 & 7000# rating which would make the trailer 12-14k rating???
The trailer is kinda beat & sits rather high???
Anyone maybe able to go check it out for me???
V10
Re: Trailer Inspection Near Pataskla OH...8 bolt axles ??? [Re: V10nacuda] #867393
11/30/10 08:47 PM
11/30/10 08:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
V10
The axles may be rated high but the frame may be rated
for 10K but you would be MUCH better off with the
big wheel and tire... the small tire trailer most
people over load them
EDIT
Also if your car is low you may need to put some
ramp extensions on... my trailer sits HIGH and
this is what I did
Re: Trailer Inspection Near Pataskla OH...8 bolt axles ??? [Re: V10nacuda] #867394
11/30/10 08:50 PM
11/30/10 08:50 PM
sg66mopar Offline
sg66mopar  Offline
The trailer manufacturer can put whatever rating on the trailer they feel it's capable of. Just because the axles are rated 6K or more doesn't mean the trailer structure is capable of that.
Once a VIN and GVW have been assigned by the Mfg. that's the trailer rating. Could even be that a previous owner changed the axles.
Re: Trailer Inspection Near Pataskla OH...8 bolt axles ??? [Re: sg66mopar] #867395
11/30/10 09:44 PM
11/30/10 09:44 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
It's a little far from me but if you don't find anyone else I can make a day of it when I get a day off
Re: Trailer Inspection Near Pataskla OH...8 bolt axles ??? [Re: V10nacuda] #867396
11/30/10 10:30 PM
11/30/10 10:30 PM
Florida-West Coast
Thor500 Offline
Thor500  Offline
Florida-West Coast
Smallest axle with 8 lugs is 7k each.
Re: Trailer Inspection Near Pataskla OH...8 bolt axles ??? [Re: V10nacuda] #867397
11/30/10 10:55 PM
11/30/10 10:55 PM
ohio ,pataskala
barabaracuda Offline
ohio ,pataskala
i live near pataskala get me the info and i will check it out
Re: Trailer Inspection Near Pataskla OH...8 bolt axles ??? [Re: barabaracuda] #867398
12/01/10 02:40 AM
12/01/10 02:40 AM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
I live in Pataskala too, let me know where to go and I will look at it for you.poppaj
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: Trailer Inspection Near Pataskla OH...8 bolt axles ??? [Re: Thor500] #867399
12/01/10 07:36 PM
12/01/10 07:36 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I had axles that where stamped 6k that had 8 lugs.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Trailer Inspection Near Pataskla OH...8 bolt axles ??? [Re: dusturbd340W5] #867400
12/02/10 12:54 PM
12/02/10 12:54 PM
NW PA
NW PA
Thanks for the replies guys!!!
POPPAJ....PM Sent
