Big Block Alternator bolt and spacer sizes
#866954
11/30/10 12:40 AM
11/30/10 12:40 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
I cannot find any of my alternator bolts and spacers. Could someone tell me how long the bolts and spacer are? Regular 60 amp alternator, standard late 60's brackets.
Thanks.
Re: Big Block Alternator bolt and spacer sizes
[Re: stumpy]
#866957
12/01/10 05:03 PM
12/01/10 05:03 PM
Posts: 21,539 It's a dry heat
gtx6970
It's a dry heat
The brackets are different between the B and Rb engines.
Ummmm, no there not
The difference is where the upper bolt passes thru the triangle bracket between B versus RB engine., Thus the 2 holes on the one end
[Re: NTOLERANCE]
#866961
12/05/10 04:24 PM
12/05/10 04:24 PM
Posts: 1,294 Ontario, Canada
FJ5_Fish
Ontario, Canada
Thanks.
What kind of alternator are you running? There was no regular 60 amp alternator - Do you have a Leece Neville alt? Those use completely different brackets.
[Re: stumpy]
#866962
12/05/10 04:26 PM
12/05/10 04:26 PM
FJ5_Fish
Ontario, Canada
There are two different bracket sets for BB and have to do with a difference on where the bolt by the thermostat goes. The two holes in those brackets don't address that problem. I ran into that with my last 383.
Unless you have some kind of weird water pump housing and/or heads the 383/440 bracket is the same - by same year.
