70 B-body steering column #866333
11/29/10 11:36 AM
11/29/10 11:36 AM
Owosso, Michigan
stateroadhog Offline OP
Owosso, Michigan
My 70 B-Body steering column does not have a lower bearing where the steering shaft comes out of tube. Is there suppose to be one? There is no place for the set screws but the shaft rubs on outer tube.My service manuel does not really say on this column. Its a 70 4 speed column.
Re: 70 B-body steering column [Re: stateroadhog] #866334
11/29/10 11:51 AM
11/29/10 11:51 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
there is a lower support for the lockout tube only
To prevent the center steering shaft from rubbing internally, you have to adjust the plate where the column attaches to the firewall
Re: 70 B-body steering column [Re: gtx6970] #866335
11/29/10 11:53 AM
11/29/10 11:53 AM
Owosso, Michigan
Owosso, Michigan
Thanks for the info thats what I thought but wasn't sure Brian
