Re: xfi and converter lockup
[Re: wireweld]
#865687
11/28/10 05:01 PM
11/28/10 05:01 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You need a new tranny guy. A regular A999's case doesn't have the passageways a lockup version uses. It isn't a matter of just adding the guts.
[Re: slantzilla]
#865689
11/28/10 06:08 PM
11/28/10 06:08 PM
Posts: 25,994 Rio Linda, CA
John_Kunkel
Rio Linda, CA
999 lockup is strictly a hydraulic function, some later ones have an electrical connection used for UNlocking the converter under certain conditions.
[Re: John_Kunkel]
#865690
11/29/10 02:03 AM
11/29/10 02:03 AM
Posts: 6,018 Salem
Grizzly
Moparts Proctologist
Salem
John:
Conditions such as applying the brake? Vehicle will stall when slowing to a stop with converter still locked, correct?
Mo' Farts
Moderated by "tbagger".
[Re: DaytonaTurbo]
#865692
11/29/10 01:06 PM
11/29/10 01:06 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
The electronic lock up was mostly to keep it un-locked at high throttle angles and mabey when cold.
Without the passages in the case you can not add lock up, well it could be done but would require a lot of money and engineering and be waaaaaaaaay more expensive than just swapping trannys. Just find one of the electronic controlled lock up trans and have it rebuilt and add your GV, it is not expensive or hard. When you go to the bone yard look for a van 89-95 with a 904 or a 89 mabey 88 V8 diplomat/5th ave. If you look on the option sheet and it says 32RH you probably found the right trans, look for a trans that looks just like a regular 904-999 and find the aditional electrical plug in near the shifter.
