Air injection ports on big block heads #865548
11/28/10 12:32 PM
11/28/10 12:32 PM
Mesa, AZ
P
Pat_Whalen Offline OP
super gas
super gas
P
Mesa, AZ
Do later big block heads have those small ports by the exhaust? I remember hearing about these ports needing to be plugged on small blocks, but not sure about bb heads.
If they do have them and they're not plugged, what is the outcome?
Any way to determine if I've got them without taking the headers down?
Thanks, and happy holidays.
-Pat
Re: Air injection ports on big block heads [Re: Pat_Whalen] #865549
11/28/10 01:03 PM
11/28/10 01:03 PM
scratchnfotraction Offline
dont think they had the holes in the heads
I think the airpump pumped it into the manny in it own passage then mixed fresh air with the exhast on the way out
that was mopars way of deluting the exhast with fresh air to lower emission at the tail pipe/sniffer
i do know most of the SB that have injection holes are most times pluged from carbon anyways
only had one that leaked with headers when I did not plug them
so I just drilled tapped the one hole
but after the rebuild and VJ,they were all open but the one pluged hole
Re: Air injection ports on big block heads [Re: Pat_Whalen] #865550
11/28/10 01:08 PM
11/28/10 01:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I've never seen them on a big block head .
Re: Air injection ports on big block heads [Re: JohnRR] #865551
11/28/10 02:53 PM
11/28/10 02:53 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
on 72 400's the air pump put air into the exhaust manifolds.
i know this for a fact on 72 road runner 400 motors. i have a set of manifolds and the matching air pump and lines that i helped remove them myself from a California emission car.
perception is 90% of reality
Re: Air injection ports on big block heads [Re: Mr T2U] #865552
11/28/10 03:01 PM
11/28/10 03:01 PM
some SB are like that as well
pumps air into the manny
other pump air THRU the manny in its own passage into the injection hole and into the exhast port floor
Re: Air injection ports on big block heads [Re: scratchnfotraction] #865553
11/29/10 12:54 AM
11/29/10 12:54 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
My 72 Imperial is a CA car. It has a smog pump blowing air into the front of the passenger side manifold. I can't see where it goes into the driver's side manifold. The hose is disconnected and plugged. The manifold may have been swapped when they replaced the exhaust.
- Stu Harmon
