95 4.0 Jeep hard to start #865350
11/28/10 10:27 AM
11/28/10 10:27 AM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
My 4.0 Cherokee Fuel Injected has been getting harder to start. I replaced the air filter and it made no difference. I went out this AM and it would not start.It would turn and turn but would not fire. What would cause this? Thanks Guys!
Re: 95 4.0 Jeep hard to start [Re: 68GTS383] #865351
11/28/10 10:51 AM
11/28/10 10:51 AM
Ohio
Todd Offline
Todd  Offline
Ohio
I would check your fuel pressure. Pump sounds like it's giving up. Cycle the key a few times and listen if the fuel pump is running.
Re: 95 4.0 Jeep hard to start [Re: Todd] #865352
11/28/10 01:51 PM
11/28/10 01:51 PM
Colorado
spk2go Offline
spk2go  Offline
Colorado
Check your crank sensor
Re: 95 4.0 Jeep hard to start [Re: spk2go] #865353
11/28/10 06:03 PM
11/28/10 06:03 PM
PA
70Duster Offline
70Duster  Offline
PA
Yep, Bad crankshaft position sensor is a very common problem.
Re: 95 4.0 Jeep hard to start [Re: 70Duster] #865354
11/28/10 10:31 PM
11/28/10 10:31 PM
NJ
440challenger Offline
NJ
Like mentioned,do you heard the fuel pump? Also isnt the crank sensor located in the bellhousing on these?
Re: 95 4.0 Jeep hard to start [Re: 440challenger] #865355
11/28/10 10:36 PM
11/28/10 10:36 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
how long have the plugs been in?
Coming soon!!!!
Re: 95 4.0 Jeep hard to start [Re: Mr.Yuck] #865356
11/29/10 12:19 AM
11/29/10 12:19 AM
Baltimore, MD
MadMax58 Offline
MadMax58  Offline
Baltimore, MD
Try this: When you first get in, just turn the key to the on position without starting it and wait until you hear the fuel pump come on. Then turn the key off and on several times. Then try and start the Jeep. My Jeep had this problem and it wound up being 3 bad leaking capacitors in my computer. There are several how-to's on the internet on how to replace the bad caps inside the computer.
Re: 95 4.0 Jeep hard to start [Re: Mr.Yuck] #865357
11/29/10 02:49 AM
11/29/10 02:49 AM
Woodburn Oregon
Two Lane Offline
Two Lane  Offline
Woodburn Oregon
Just worked on a customer same year / engine Cherokee. Came in to replace the front diff assy and went to start after work was done- (had to tow in due to dead battery)- didn't want to start (cranked fine) LONG story short- held pedal to floor - finally started but took until it was warmed up to finally idle. Cleaned throttle body (filty black) Plugs were shot- never does maintenance. End of that story. Hope this helps- like other guys noted- very common for crank sensor to go. Check for spark!
"Do you know why I stopped you?"- "No" - "Your license plate was laid down"- "Oh that,- that only happens when I Floor it"
Re: 95 4.0 Jeep hard to start [Re: 440challenger] #865358
11/29/10 11:34 AM
11/29/10 11:34 AM
PA
70Duster Offline
70Duster  Offline
PA
Isnt the crank sensor located in the bellhousing on these?
Yes, At the 11:00 position standing under the transmission looking toward the engine.
